V 9.0.58 problem
w4gv
#1 Posted : Tuesday, May 28, 2013 12:23:17 PM(UTC)
Downloaded the new fix and the import of ADIF log files from Writelog works but now I can't download qsls from LoTW or eQSL. Immediately before the upgrade, I was able to download QSLs from both sites. Now, eQSL basically says that the file downloaded is not in ADIF format and LoTW is unable to login. I was already logged into both sites before attempting the downloads. It has always worked in the past.
Anyone else?
Walt W4GV
w4gv
#2 Posted : Tuesday, May 28, 2013 12:37:37 PM(UTC)
Also noticed that when I restart Logic, I now get an error "nisttime error 232 winsock". Able to connect with other sites using IE (including Hosenose.com, which I'm using to send this.
w4gv
#3 Posted : Tuesday, May 28, 2013 6:20:40 PM(UTC)
Has anyone else run into this problem or am I the only one?
#4 Posted : Tuesday, May 28, 2013 9:41:24 PM(UTC)
No problems here -- I imported both LoTW and eQSL. Plus we didn't change anything having to do with these.
A theory: You have an internet protection program that is blocking LOGic from accessing the internet. It worked before, but detected that LOGic is in fact a different program now and started blocking it again. Try turning off anything like that and test it. If that is it, tell it to allow LOGic to access the internet.
w4gv
#5 Posted : Wednesday, May 29, 2013 5:25:02 AM(UTC)
Couldn't find the problem and internet seemed to be working as did Logic (on most things).. Finally did what we've all learned to do - reboot. Things are running seamlessly as before now. Sorry for the false flag. You've got a great program Dennis.
