Posts: 19 Location: Hudson, NY
Thanks: 8 times Was thanked: 1 time(s) in 1 post(s)
Is there a way to see only spots posted by US stations in the spot log?
Logic9 will be able to do that. That would be nice indeed. Stargate1!!
LOGic 8 will do it too. Go to the OPTIONS tab in the spot log. Click the FILTER button to the right of PREFILTER. Set SPOTBYDXCC equals K_
What may actually be better is to set SPOTBYMI to <= say 1000.
The only version of the formula that logic excepts seems to be (SPOT_BY='K' OR SPOT_BY='VE'). It won't except the previous post of yours; spotbydxcc=k. Will this allow me to see both us and ca spots?
tnx Kevin km2e
My post was assuming using the filtering GUI rather than typing in the expression.
What you did is correct also. Except I would put a space after the K: SPOT_BY='K ' OR SPOT_BY='VE'
This will prevent processing spots from say KH6XX.
