Modes; Awards Progress, Invalid Mode "Phone"???
K2WH
#1 Posted : Saturday, April 27, 2013 1:50:39 PM(UTC)
I have Logic8 and when trying to update awards progress, I get about 2,000 rejects with the program telling me "Phone" is an invalid mode. How do I correct this?
K2WH
#2 Posted : Sunday, April 28, 2013 8:41:17 PM(UTC)
G'Day,
Valid modes are managed by using Tools, Setup, Modes.
There you will see all the valid modes listed, with "PHONE" the code to bring together all the various modes - AM, FM, SSB, USB, LSB to track awards. But, PHONE is not a mode that you should use in a QSO.
Did you recently import QSOs from another program?
How did "PHONE" get into your QSOs?
K2WH
#3 Posted : Monday, April 29, 2013 5:33:08 AM(UTC)
G'Day,
I recently went from Windows XP to Windows 7 by using a transfer cable to the Windows 7 computer. The log file lists at least 1,900 QSO's that have the mode "Phone" in there. I didn't put them there, it must have happened during the transfer. The only way to correct it that I see is to manually change all 1,900 entries back to SSB unless you know of a global way of doing it.
Bill
K2WH
#4 Posted : Monday, April 29, 2013 5:58:31 PM(UTC)
Hi Bill:
Strange -- I don't think anything with transferring the data would do it. After all, you are just copying files.
Anyway, it is easy to fix. You can even set it to SSB and LSB as appropriate.
First make a backup of your log.
Go to tools/advanced/database commands.
Type:
USE LOG
REPLACE MODE WITH "LSB" for BAND="80M" AND MODE="PHONE"
REPLACE MODE WITH "LSB" for BAND="40M" AND MODE="PHONE"
REPLACE MODE WITH "USB" for BAND="20M" AND MODE="PHONE"
etc etc.
You COULD replace everything below 14 MHz with "LSB" and everything above with "USB", but I am concerned that Frequency, being optional, may not be logged, FM QSOs on 2M etc. This way is conservative and gives you more control.
K2WH
#5 Posted : Monday, April 29, 2013 7:39:40 PM(UTC)
Hi Bill:
Type:
USE LOG
etc etc.
Thanks for the hint on how to fix this. However, I do alot of digital work and many of the contacts are PSK31, JT65, JT9, MFSK16 etc. Can a 3rd argument be included in the command line for frequency?
Bill
K2WH
#6 Posted : Thursday, May 2, 2013 12:56:43 PM(UTC)
Ok, so are you saying that the mode should actually be PSK31, JT65, etc etc, and you want to fix the mode based on frequency? I gather there is a small range of frequencies that you use for each of these.
Yes, it can be done:
USE LOG
REPLACE MODE WITH "PSK31" for BETWEEN(FREQ, 14.0695, 14.0705) AND MODE ="PHONE"
or if it is really 14.070:
REPLACE MODE WITH "PSK31" FOR FREQ=14.07 AND MODE ="PHONE"
K2WH
#7 Posted : Thursday, May 2, 2013 7:18:10 PM(UTC)
USE LOG
Dennis, thanks for all the help and I am following you with what can be done and I believe it is the solution I need. One little thing left. How do I execute the command lines? I don't see anything that says "Execute" or "Run" etc. I am typing in what you said and it is understandable and I hope I am typing the commands in the appropriate box. The box I am typing in is a small box called "Command". Is this where I should be and how do I execute the string or in other words, how do I tell it to "Go"?
Bill
K2WH
#8 Posted : Thursday, May 2, 2013 7:30:18 PM(UTC)
G'Day Bill,
It sounds like you are in the right place.
One types these commands into the COMMAND widow from Tools, Advanced, Database Commands.
The commands are executed when you press <enter> at the end of the command line.
If no error occurs - the cursor sumply returns ready for the next command.
When finished, type EXIT<enter>
This is a "risky business" - easy to make a mistake and change your log in ways you never intended. Take lots of backups of your log - both before and after you run a set of commands in the Command Window.
This page was generated in 0.144 seconds.
