LOGic Forum
LOGic Support
All Other
Boot up problem - GLOBAL
Posts: 5 Location: Pinehurst, NC
Running version 9.0.43: Often, but not always, I get an Error: "Alias 'GLOBAL' is not found" OR "GLOBAL is not an object" when booting up the program. It will not clear and it cannot be ignored and the program will fail to execute. On a second or third try it will usually boot up OK.
It did the same thing in my previous version 8, and I thought it might just go away and leave me alone with the upgrade. But no.
Running Windows 7.
Any ideas?
Usually you see that when you exit after another error.
I would start by upgrading to the latest update.
Try temporarily turning off your virus checker. What are you using?
Updated to latest version and have not had the problem again in the past 3 weeks. BTW, am running McAfee. Am cautiously optimistic that the upgrade solved the problem. Thanks...
LOGic Forum
LOGic Support
All Other
