Searching a call in the log
#1 Posted : Monday, April 15, 2013 9:48:35 AM(UTC)
Hello Dennis,
I wanted to point out that when I use the filter to search for a CALL in my log, the final report also includes other similar CALLS. In fact, when you insert the CALL with the Operator option as "= equal", it would seems the used Operator has been as "$= contains". Look at the attached screenshot. Thank you.
#2 Posted : Tuesday, April 16, 2013 5:16:29 PM(UTC)
Hi Mauro,
This is how it has always worked - by design. From the Help, for "Filtering", ...
Partial match
With fields that contain character data, you may enter only the first part of a value in the field, and only the number of characters entered will be matched. For instance, ROB will display ROB, ROBERT, ROBBIE, ROBERTO, and ROBERTA. Entering R will find everyone whose name starts with the letter R! You may disable the partial match feature by putting an underscore (_) after the value. For instance, ROB_ will locate only ROB, not ROBERT, ROBERTO, ROBERTA, etc.
CALL is a character field.
Peter VKIU
2 users thanked vk4iu for this useful post.
IK0CHU on 4/17/2013(UTC), WN4AZY on 4/17/2013(UTC)
#3 Posted : Wednesday, April 17, 2013 7:58:28 AM(UTC)
Hi Peter,
thanks for the useful information.
I was not aware of the use of the underscore character to make a filter.
