GQSL field
#1 Posted : Monday, January 23, 2012 9:54:59 PM(UTC)
Dennis, on the main log form I see a field labeled GQSL. What's it for? No mention of it in help.
#2 Posted : Monday, January 23, 2012 10:33:14 PM(UTC)
It is for Global QSL Sent. It is not implemented yet, and is hidden by default. It probably magically appeared if you copied a LOGic 8 log form.
Just unlock the form and drag it into the trash can. Or, it is actually hooked into the database, so if you wanted to use it you could.
k1ps
#3 Posted : Wednesday, March 20, 2013 8:31:07 AM(UTC)
I am trying to use GQSL_sent. I realize that you are not supporting this, but thought I'd ask a question in a more global sense.. no pun intended. After I send an ADIF file to GQSL, I'd like to change the entry in the field from blank or "R" to "F" between two dates.
In a larger sense, can I change an entry in any field from one entry to another between two dates?
Pete, K1PS
ps thanks for your recent help.....
#4 Posted : Thursday, March 21, 2013 6:55:17 PM(UTC)
Go to tools/advanced/database commands. Type
USE LOG
(There is an open file button, but this is easier).
Now go to DATABASE FILES/MASS CHANGE/REPLACE FIELD CONTENTS. Fill out the form. The REPLACE THIS FIELD would be GQSL. Click the funnel next to REPLACE ONLY IF and fill out the form -- QSO Date, BETWEEN, and enter your dates.
REPLACE WITH would be "F" for Fulfilled.
Let me know if any ???s.
#5 Posted : Tuesday, March 26, 2013 10:50:13 AM(UTC)
Any idea when this feature will be implemented?
