Posts: 7 Location: rathbun, iowa
I have been trying to import logs from ham radio deluxe with no luck. Any ideas ??
Jim
Groups: Moderator, Registered, Administrators Posts: 404  Location: Hodgleigh QLD Thanks: 6 times Was thanked: 77 time(s) in 68 post(s)
G'Day, A little more information is needed? What did you do to import the data? What happened? When you say "no luck" ... what did not work? Peter VK4IU Peter VK4IU You can help by posting images of any errors and including your Logic version.
Groups: Administrators, Beta Testers Posts: 3,256  Location: Auburn, GA Thanks: 1134 times Was thanked: 553 time(s) in 463 post(s)
Hi Jim:
Have you managed to export your HRD data to an ADIF file? This is the first step, and unfortunately we can't be a log of help because the procedure varies from program to program. Just search HRDs help for ADIF EXPORT. It typically isn't difficult.
