Bad TX Freq for spot
#1 Posted : Monday, March 4, 2013 7:21:49 PM(UTC)
While listening for the DX Operation on Clipperton Is today - the calculation for TX Freq for the spot results in a corrupted frequency. If one attempts to "Set Rig" to the spot, an error dialogue results - as one would expect.
Clicking Ignore allows Logic to continue. The rig RX freq was set correctly.
I am using Logic 9.0.53.
Bad TX Freq from spot comment
Click Ignore  - continues successfully
#2 Posted : Wednesday, March 6, 2013 12:52:48 PM(UTC)
Sorry, I cannot reproduce that here.
I am wondering if it is decimal format? But you guys use a period like us, right? That's what the screen shot shows.
Try some test spots similar to what I have done and see if you get different results. Perhaps the test spot feature is not a good test for some reason.
#3 Posted : Wednesday, March 6, 2013 4:19:07 PM(UTC)
.. I wonder what happend to the image I put in the post. Here it is again ..
Bad calc
It is a snap of the spot log - "as it happened", so to speak.
But, you are correct. I tried the test spot, and that functioned correctly. I tried 3.5, and 3,5 both seem to now function.
Clearly there is some other side affect at work here.
I do not remember if I tried the test spot last time. I think I might has simply accepted what was in front of my eyes - the image above of the spot log.
Peter VKIU
#4 Posted : Sunday, March 10, 2013 9:42:17 AM(UTC)
Ok, it is treating the "2.9" as an actual frequency in mhz. But where is it getting the "014.0329 part from"?
Where is the spot coming from -- Telnet or DX Summit? I would like to see the actual spot from Telnet or the web browser.
Is Clipperton still active?
#5 Posted : Sunday, March 10, 2013 5:40:44 PM(UTC)
G'Day,
I think we should go on to other things - I have no records left of the incident.
The spot came from a Telnet link to CC-USER of VE7CC, running on another PC on my network, connected to VE7CC-1. But, the data is long gone. I have no records of it now. Sorry about that. I should have kept more information of the incident.
Clipperton Is closed down about 24 hours ago.
