Log form layout - Browse window
#1 Posted : Saturday, February 9, 2013 8:38:25 PM(UTC)
G'Day Dennis,
If have set out my screen for operating two radios with Logic. This setup is for "operating" as compared to analysis, or QSLing, or printing reports.
Two radio screen layout
The log forms do not include the Browse window. I load it when I need it, and close it after any use. When loaded they cover the Spot log.
The two log forms are set to load with Logic in the usual way. I get everything set the way I want, and close Logic so the positions are remembered etc etc.
However, the Browse window for the FIRST log form will just not stay closed - the top item SET in the Forms/Log dialogue. It opens by itself when Logic is loaded, and any other activity that causes Logic to "initialise".
Maybe I have missed something, but I would rather the Browse window stayed closed until I want it.
I did a little "sniffing around" in the Main-LEFT.logform and discovered the BrowseVisible=xxx setting. If I manually change BrowseVisible to NO, the Browse window stays closed. But the moment I open the Browse window, even if I then close it, when I exit Logic, BrowseVisible for the form is reset to YES.
It seems that the "state" of the Browse window is not being remembered correctly.
#2 Posted : Tuesday, October 29, 2013 12:04:04 AM(UTC)
Have you had time to examine/think about this issue.
My priority: Medium
