LOTW Upload problems with LOGic 7.0.132
w5gai
#1 Posted : Wednesday, January 30, 2013 11:26:05 PM(UTC)
I use LOGic 7.0.132 with a Windows XP Version 2002 Service Pack 3 on a Dell D620 Laptop.
When I try to Export and Upload QSO's to LOTW it goes through the steps OK until I click on Export,
process, and upload.
LOGic tries to upload the tq8 file and that fails.
The ARRL LOTW page appears.
It says Uploading, then a popup window comes up that says Upload Failed
And on the LOGic Upload QSOs to LOTW window it says Upload Failed
I then use the LOTW page to upload the tq8 file and it processes OK.
But I do not get LOTW QSL sent check box recorded in LOGic, so I have to keep a note of the last uploaded QSO
for the next time I want to upload.
Any suggestions on
1. how to make the upload process work?
2. how to get LOTW QSL sent recorded in LOGic?
3. is there a later version of LOGic 7 that will fix this that I can download?
#2 Posted : Thursday, January 31, 2013 3:07:36 PM(UTC)
When did it work last? It seems to me they changed their servers or something a few years back.
Here is the lastest update to LOGic 7:
http://hosenose.com/ftp/...logic7/logic7update.exe
I don't know the version number, but the timestamp is Feb 2006. I'm feeling like you have the latest LOGic 7.
You can use these commands to mark LOTW SENT after you upload:
Go to tools/advanced/database commands. Type:
USE LOG
REPLACE ALL LOTW_SENT WITH .T.
This info may be useful:
http://hosenose.com/Foru...ing-LoTW-and-LOGic.aspx
It tells how to intercept the file that LOGic creates so you can upload it manually.
Tnx for using LOGic.
w5gai
#3 Posted : Friday, February 1, 2013 2:22:48 PM(UTC)
Dennis:
Thanks for the LOGic 7 update link.
I upgraded from ver. 132 to 163.
Logic would not reload without errors.
It said among other things that log.dbf was not assessible.
Clean did not work.
Rebooted the computer and LOGic came up OK.
Uploading to LOTW worked flawlessly this time.
And the LOTW sent flas was also set for the QSO's uploaded.
Can you advise me what feature3s does LOGic 9 have that LOGic 7 does not?
Skip W5GAI
#4 Posted : Tuesday, February 5, 2013 10:37:19 AM(UTC)
Glad it works!
Here is the link to LOGic 9 new features.
http://hosenose.com/LOGic_9_FAQs.aspx
Also, you should have gotten a newsletter. Let me know if you want me to send it again.
The big things with LOGic 9 are the band map, new world map, tracking for more awards like CQ Field using the new calculated fields, easy cabrillo export formatting using templates, new CW keyer, support for HAMQTH callbook (Lots of international, and free and fast), better radio interfacing with COMN port sharing with CW keying, OmniRig support ....
Here are the LOGic 9 updates
http://hosenose.com/Foru...features-and-fixes.aspx
We just added a whole new thing for prefix table lookup that makes support of the russian prefixes etc easy.
Attached is an old web page with LOGIc 8 new features.
What's new 8.zip (223kb) downloaded 141 time(s).
NP3K
#5 Posted : Thursday, January 29, 2015 11:45:53 AM(UTC)
I have the same error with Logic 8, can you provide the fix?
Charlie NP3K
#6 Posted : Monday, February 16, 2015 5:38:16 PM(UTC)
It is the same workaround as LOGic 7. I made a clean thread here:
http://www.hosenose.com/...g-to-LOTW.aspx#post4658
