Ok, first of all, you have log.dbf. But do you have log.fpt also? Log.fpt contains the notes and addresses. The two files should always travel together. If you do not have log.fpt, it is possible to recover everything except the notes and addresses.
Or better yet, do you have a backup made with tools/backup, or a copy of your whole LOGic folder?
Please advise.
Once we have a good backup, it is just a matter of doing a backup of what you have now, using tools/advanced/database commands to delete everything 07/01/2012 and after, then restoring your backup, using the option to "Append data", and "if a QSO is in your log and on the backup, Keep the QSO in the Log".
I can give more detailed info on doing this when we make sure we have a good backup as of 07/01/12. If you don't, we can still recover your data, it just won't be simple.
Tnx & 73, Dennis
