Program Error
AJ4F
#1 Posted : Monday, January 14, 2013 7:41:06 PM(UTC)
I am Running Logic 9 .50 and started getting the following error on start up:
Program Error
OLE error code 0X000040154 class not registered
Please recommend how to proceed!
Thanks in advance,
Robie - AJ4F
#2 Posted : Monday, January 14, 2013 8:46:14 PM(UTC)
Strange -- it just started happening? Is there any other information in the error message?
Try installing the CD then the .50 update again. Don't uninstall first, just install on top of what is there. It shouldn't affect any of your data or setup, but it wouldn't hurt to make a copy of the LOGic folder first.
Let us know!
AJ4F
#3 Posted : Monday, January 14, 2013 10:04:59 PM(UTC)
Re-installed Logic 9 and .50 update. Started Logic 9 and got the same error!
The problem started after a recent .NET security update.
Robie - AJ4F
#4 Posted : Tuesday, January 15, 2013 8:08:46 PM(UTC)
Is this the update? I will try installing it here and see if it causes mine to fail. No other reports of problems yet tho. LOGic uses .net V 2 still.
What version of Windows are you running?
#6 Posted : Tuesday, January 15, 2013 8:31:10 PM(UTC)
Ok, no problems here with that update on Win 7 Home Premium 64-bit.
If you ignore the error, what feature doesn't work?
Is User Account Control turned off?
AJ4F
#5 Posted : Tuesday, January 15, 2013 9:23:27 PM(UTC)
Thanks -
No the update you show is not the latest on my computer. To the best of my knowledge the last update to my computer is:
Microsoft .NET Framework 3.0 Service Pack 3.0 KBD2756918 installed on my computer 1/12/13
I am running Windows XP Home Edition SP3
Robie - AJ4F
AJ4F
#7 Posted : Tuesday, January 15, 2013 9:39:28 PM(UTC)
If I ignore the error I get the following:
Program Error
Unknown Member Spotlogref
At this point Logic has read and displayed my transciever frequency!
If I ignore this error I get the following:
Logic 9
OLE Error code 0X080040154
Class not registered. Class containing OLE Object is being Ignored Record Number 4
When this occurs the Telnet window has opened.
I do not know where to determine the status of User Account Control.
Robie - AJ4F
#8 Posted : Wednesday, January 16, 2013 11:05:12 AM(UTC)
Ok, a problem with sound then. Try this:
Install this on your system:
http://slimdx.org/download_mar11.php
Click the INSTALL NET 2.0 button.
I think that will fix it. I don't see how the .NET update screwed it up in the first place tho.
To determine the status of UAC, type UAC in the Windows search box.
AJ4F
#9 Posted : Wednesday, January 16, 2013 9:37:04 PM(UTC)
Thanks for the suggestion and the link. I did the install, however it made no difference. I get exactly the same errors.
Robie - AJ4F
#10 Posted : Thursday, January 17, 2013 9:28:40 AM(UTC)
Ok, pse call me and I can log in and take a look. I'm at a loss at this point.
AJ4F
#11 Posted : Thursday, January 31, 2013 7:51:06 PM(UTC)
Following your suggestions I uninstalled and re-installed the .NET components on my computer and Logic 9 now works properly!
Thanks for your support!!
Robie - AJ4F
#12 Posted : Sunday, February 3, 2013 4:47:20 PM(UTC)
Ok, cool. Thanks for the update.
For future reference, Robie was getting errors about system.drawing not found, a very basic part of the .NET framework. He tried reinstalling the 2.0 service pack 2, but it said it was already installed, and as I recall the REPAIR option did not fix the problem. Here is the .NET cleanup tool he used:
http://blogs.msdn.com/b/...2008/08/28/8904493.aspx
Guest (5)
