Logic 7 user
LU1BJW
#1 Posted : Wednesday, December 12, 2012 3:41:16 PM(UTC)
Dear Dennis,
Wooowwww The time goes by ... since Logic 4 (DOS).
Today I installed the new Logic 9 and the update file 49.
In logic 7 I have more than 40.000 contacts with a lot of
information per QSO (BIO+#1010+#VP+#JCC+#DIG+#DOK+Counties+LOC+etc+etc+etc)
with a customized entry window.
All that complete information per QSO... is going to be transfer with the export tool at
logic7 and imported by Logic9?
Are there a way to import my costomized entre window, intestead of
set up a new one on Logic9?
Please think about it and pass me you tips in order do not loose
thousends of hours loading information in Logic7 database.
thanks for your support during many years of Logic.
Best 73
Horacio - LU1BJW
#2 Posted : Friday, December 14, 2012 11:29:24 AM(UTC)
Groups:: Administrators, Beta Testers
Hi Horacio:
Yes, just do a backup in LOGic 7 and a Restore in LOGic 9. Choose OVERWRITE for the restore option and it will bring in the Biographical info and all user-defined fields. Of course you aren't actually overwriting anything since LOGic 9 is empty.
You can try to copy the LOGic 7 log forms to LOGic 9. The LOGic 8 ones are compatible, but I can't say for sure with LOGic 7.
Thank YOU for using LOGic for so many years!
LU1BJW
#3 Posted : Friday, December 14, 2012 2:27:51 PM(UTC)
Hi Horacio:
I already import de database, however to do what you suggested I have to delete the imported database to start again. How can I delete it and clean all?
Horacio
#4 Posted : Sunday, December 16, 2012 10:35:08 AM(UTC)
Ok, you want to get rid of all QSOs in the log, then restore?
To delete all QSOs in the log, go to tools/misc utilities/zap log.
LU1BJW on 12/17/2012(UTC)
LU1BJW
#5 Posted : Monday, December 17, 2012 7:17:20 AM(UTC)
Originally Posted by: LU1BJW Go to Quoted Post
Dear Dennis,
Best 73
Horacio - LU1BJW
Good Morning Dennis,
I'm still trying to build with up to 15 user defined fileds the main entry window. I said trying because I defined the fields but do not show in the windows.
Backup and restore:
I did a complete deleto of all qso and then, after a backup on Logic 7 I restored on Logic 9.
The problem the the BIO notes, did not appear on the new Logic.
Any tips?
Best 73
Horacio
#6 Posted : Monday, December 17, 2012 11:53:12 AM(UTC)
Ok, the data came across no problem. You just need to first make sure the fields are defined in tools/setup/log fields, then add them to the log form.
You can try copying your LOGic 7 log forms into LOGic 9 (goes in the logdata/logforms folder). You can do that with LOGic 8, but I am not sure about LOGic 7.
LU1BJW
#7 Posted : Monday, December 17, 2012 12:10:49 PM(UTC)
HI Dennis,
I tryed to move the logform from Logic 7, but did'nt work. So I started again.
Prodedure: I defined the fields in tools/menu/logfields, and I don't remember how to add them to the log form.
And what do you suggest about the BIO info not restored from the Logic 7 back up?
regards
Horacio
#8 Posted : Monday, December 17, 2012 8:00:43 PM(UTC)
Sorry I forgot your question about Bio.
Look in the TMP folder inside the LOGic install folder. There should be LOG_BIO.DBF and LOG_BIO.FPT in there. Copy them to the LOGDATA folder. (If they are not in the TMP folder, do a restore and select "do nothing" with the data.
Look in Help, under User Defined Fields.
LU1BJW
#9 Posted : Monday, December 17, 2012 8:42:39 PM(UTC)
Bio Info:
I copied the following files from Logdata folder of Logic 7 to the same in Logic 9:
LOG_BIO.DBF
LOG_BIO.FPT
LOG_BIO.CDX
Then I run clean index.
And run the Logic again.
The BIO info do not appear.
Any suggestion?
Horacio
LU1BJW
#10 Posted : Wednesday, December 19, 2012 10:23:53 AM(UTC)
Bio Info:
LOG_BIO.DBF
LOG_BIO.FPT
LOG_BIO.CDX
Any suggestion?
Horacio
Yesterday I try:
Unistall Logic 9
Install Logic 9
Install Update 49 of Logic 9
Backup database in Logic 7
Restore Backup of database of Logic 7 in Logic 9.
From Logic9/temp/
LOG_BIO.DBF
LOG_BIO.FPT
I checked if the info are in the files.
Then
In Logic9/Logdata
I rename the existing LOG_BIO.DBF and LOG_BIO.FPT as oldLOG_BIO.DBF and oldLOG_BIO.FPT
I copied from the Logic9/temp/ to Logic9/Logdata.
Result: the Bio info it is not there.
Help!!!!
best 73
Horacio
#11 Posted : Friday, December 21, 2012 2:37:55 PM(UTC)
Please post your LOGIc 7 log_bio.dbf and log_bio.fpt here (zip them up), or email them to me. I will install them here and see what is going on.
LU1BJW
#12 Posted : Friday, December 21, 2012 2:50:15 PM(UTC)
Hi Denis,
I already sent to your email address
Regards
Horacio
LU1BJW
#13 Posted : Saturday, December 22, 2012 3:01:29 PM(UTC)
Hello Denis,
Please tell me if you received the files.
Horacio
#14 Posted : Monday, December 24, 2012 4:59:04 PM(UTC)
Yes, I got your data -- thanks for sending it.
Here is what I think happened. The CALL fields are different lengths in LOG and LOG_BIO.
So go to tools/advanced/database commands. Type
USE LOG
MODIFY STRUCTURE
Note the size of the CALL field. 16 probably.
Now type
USE LOG_BIO EXCLUSIVE
MODIFY STRUCTURE
Change the size of CALL to match what was in LOG (16 for example).
Let me know!
Merry Xmas,
LU1BJW
#15 Posted : Tuesday, December 25, 2012 10:57:10 AM(UTC)
USE LOG
MODIFY STRUCTURE
Now type
MODIFY STRUCTURE
Let me know!
Merry Xmas,
Dear Dennis,
Thanks. Merry Christmas to you and yours.
After executing...
USE LOG
MODIFY STRUCTURE
The menu brought me to the open de Log_bio,
after open it I see the structure and the call field is 12 characters long.
Then I execute ...
MODIFY STRUCTURE
And the log field is not editable to change it for 16 characters long.
As I don't low how to work with this kind of commands,
may be I missed something obvious.
What do you think?
Horacio
#16 Posted : Wednesday, December 26, 2012 11:07:30 PM(UTC)
Make sure that all other forms are closed, and that
USE LOG_BIO EXCLUSIVE succeeds
It sounds like LOG_BIO is open and when that happens the MODIFY STRUCTURE command opens a window, but the title bar says (READ ONLY) and it won't let you change anything.
The next update will fix this automatically. Shouldn't be too long. Feature creep....
73 & happy new year,
LU1BJW
#17 Posted : Thursday, December 27, 2012 1:34:17 PM(UTC)
Dear Dennis,
It works!!!!!
I will continue with configuractions and table corrections.
Hope to switch to Logic 9 definitively before new year evening.
Thank you for your support.
Happy new year
Horacio - LU1BJW
Guest (8)
This page was generated in 0.307 seconds.
