Lists for Award tracking
#1 Posted : Monday, December 10, 2012 5:56:07 AM(UTC)
G'Day All.
Attached are files that represent Lists of "valid values" for my use in Logic. I use Logic 9.
JCC.DBF, JCG.DBF and KU.DBF - Japanese cities, guns, Ku list. See http://www.jarl.or.jp/English/4_Library/A-4-5_jcc-jcg/jcc-list.txt and http://www.jarl.or.jp/English/4_Library/A-4-2_Awards/Award_Main.htm
EAP.DBF - Spanish Provinces. See http://www.ure.es/awards...rd-english-version.html
SPPA.DBF - Polish counties or powiat. See http://awards.pzk.org.pl...skie-dyplomy/sp-pa.html
SPW.DBF - Polish regions or wojewodztwo. http://awards.pzk.org.pl...kie-dyplomy/polska.html
DD.DBF - German Districts. Initial letter of the DOK code.
DOK.DBF - German DOK. Data extracted from several sources. See http://www.darc.de/referate/dx/dok/
OKD.DBF - Czech districts. Note that because of the "non-english characters" some characters will appear as ?.
OKC.DBF - Czech counties. Note that because of the "non-english characters" some characters will appear as ?.
VKS.DBF - Australian Shires. There have been big changes to this list in the past few years. The list is from the Worked All VK Shires contest - VK works the world.
RBA.DBF - Russian Baltic Award. See http://www.rz1cwc.qrz.ru...g/awards/cca/cca_e.html
The list names are short so as not to consume too much space in the limited space of USERFIEDS - a 254 character limit
Some of these lists are provided with Logic. I have rebuilt these lists for my needs and to reflect the latest updates. My lists sometimes include data in the description fields of each record for cross check purposes. One can see the material in the dropdown box for the field on a log form when processing a QSL card.
The lists are ready to be imported into Logic.
Open the Lists form from Awards, Setup, Awards lists--DXCC, etc
If you want to save your exiting list, double click on its CODE in the list to the right of the Lists form, and export the list to a file of your choice. Or, rename the list, using the buttons provided. If you rename the list, think about whether nor not you need to rename the associated USERFIELD as well.
Download the attached file to a folder of your choice on your PC.
To import an attached list, click "Import list", and navigate to the file you downloaded above.
You should now have an updated or perhaps new list.
Please see the Logic Help for detailed instructions on what to do next. In the Help Contents look for Awards Tracking and Progress.
If you have already setup JCC/JCG for example, the new data, for new QSL cards, will appear automatically.
Special Note: My JCC list contains LEADING ZEROS - what usually appears on QSL cards. The original JCC list has no leading zero for numbers below 1000 - 102 as compared to my list 0102 SAPPORO (HOKKAIDO)). If you import my list, your data will still be in UESRFIELDS, but will not be shown in a JCC field on the LOG form as you browse your QSOs. You can use Data Commands, Mass Change, Replace User-defined field contents to add the leading zero to old data.
For those less familiar with what to do next, in summary, you will need to the following.
In Awards, Setup, User-defined fields setup, create a user-defined field, with the same name as the list, to hold the data you enter from your QSL cards, and mark this new field as "Edit using list table".
On the Awards panel, mark the field - "Track Awards for this field", and other boxes as appropriate.
On a log form of your choice, click the "butler", and add this new user field to the form.
Update at least ONE QSO record from your QSL cards with the indicated value from the list, using the userfield dropdown you placed on the log form.
Then use Awards, Update Awards Progress Info.
Then, open Awards, Progress List, select the award (list name and USERFIELD name) . Click NEXT.
For JCC ... you should see that there are 812 total JCC entries and your progress listed below. There are actually 909 JCC entries in the list, but 97 are actually "deleted" entries. 812+97 = 909.
If you find any mistakes that I have made, if you know where to find a good explanation of JCCs, JCGs, Kus, Prefectures, JA call areas, and their relationships, please post a reply. I am curious why some JAs nominate a JCC, some a JCG, still others a KU, on the their cards. Yet all the numbers seem related.
I appreciate any contribution to my efforts.
JCC.DBF (418kb) downloaded 110 time(s).
JCG.DBF (287kb) downloaded 117 time(s).
KU.DBF (85kb) downloaded 110 time(s).
EAP.DBF (25kb) downloaded 111 time(s).
sppa.DBF (175kb) downloaded 119 time(s).
#2 Posted : Monday, December 10, 2012 6:00:11 AM(UTC)
... it seems we are limited in size and/or the number of files.
SPW.DBF (8kb) downloaded 132 time(s).
dd.DBF (13kb) downloaded 113 time(s).
DOK.DBF (539kb) downloaded 112 time(s).
SPW.DBF (8kb) downloaded 111 time(s).
OKC.DBF (7kb) downloaded 112 time(s).
#3 Posted : Monday, December 10, 2012 6:06:07 AM(UTC)
... and 5 more ...
OKD.DBF (41kb) downloaded 114 time(s).
VKS.DBF (261kb) downloaded 102 time(s).
RBA.DBF (15kb) downloaded 126 time(s).
#4 Posted : Monday, December 10, 2012 10:07:20 AM(UTC)
Thanks Peter! That was a lot of work!
We have some Japanese customers who are not on the Forum. I will email and ask about JCG, JCC, and KU.
I guess you know about this
http://www.jarl.or.jp/En...4-5_jcc-jcg/jcc-jcg.htm
The link to Kus is broken. There is also "Shicho", also broken.
Reading between the lines, JCC is City, JCG is Gun. Which I was guessing is about equialent to US Cities and Counties. Wikipedia confirms, except that it says Guns are no longer in use. However, the article is not well-written. http://en.wikipedia.org/wiki/Districts_of_Japan
As for Ku, it is a subdivision of a city. http://en.wikipedia.org/wiki/Wards_of_Japan
So I'm thinking a JA station could have either a JCG# or JCC#, but not both. A station with a JCC# could also have a KU????
It's a complicated hobby!
Tnx again & 73,
#5 Posted : Monday, December 10, 2012 10:20:01 AM(UTC)
Ok, I found a small problem with at least some of your lists. The FIELD_TYPE field contents are lower-case in at least some cases. They need to be upper case.
The fix is simple. Just import all the lists you want, then go to tools/advanced/database commands. Type:
use lists
replace all field_type with upper(field_type)
may as well do FIELD_NAME to be safe.
replace all field_name with upper(field_name)
No need to update & reupload your lists. It would be a good idea for me to add this to our import code anyway. I am working on another update and will add it.
#6 Posted : Monday, December 10, 2012 3:29:30 PM(UTC)
G'Day,
This is a lot trickier than it looks.
You are correct the field_type is in lower case ... but it looks upper case on my spreadsheets. I did not notice.
I did not find that link for JCC/JCG/Ku list. I started here JCC/JCG/KU and the KU list is actually an Excel spreadsheet. The JCC and JCG leads to the same place I used.
#7 Posted : Monday, December 10, 2012 4:15:23 PM(UTC)
G'Day,
I started at JA Prefecture on Wikipedia. Never found the JA Districts item.
The Districts link, towards the bottom, in the External Links, has a reference to a PDF file, with a graphic on Page 7 of the document. That diagram and the rest of the article told me more than I had found elsewhere.
All that history is one thing. What is actaully on the JA QSL cards is the key to success.
I now see why some put JCC, some put JCG, some reference a Ku, etc etc.
This page was generated in 0.077 seconds.
