working with more than one radio
4z5sl
#1 Posted : Saturday, December 8, 2012 3:54:04 AM(UTC)
hi.
i have 3 Radios connected to my PC.
i click "Set rig" in the "Spot Log" form to change the Radio frequency to selected spot. This works OK, but I get an error message when i click "undo" in this "Spot log form.
i found out that this is not happening if the radio number i am using, is selected in the "Log-USERFIELDS" form (i.e.number is red)
CAT was working OK even thougt NO Radio numbe was red in the "Log-USERFIELDS"
Logic does not force me to select the Radio. shouldn't it?
73 Dan
4Z5SL
#2 Posted : Wednesday, January 2, 2013 9:34:12 AM(UTC)
Hi Dan:
Thanks for reporting this.
It has been fixed, and the update should be available late today.
Shalom/73,
4z5sl
#3 Posted : Saturday, February 2, 2013 5:10:08 PM(UTC)
Hello Dennis.
Thank you for the new version.
The error is gone, however, if i do not select the radio number 3, the frequency in the log, is not updated to the active frecency.
I use radio number 3. Radio number 1 and 2 are disabled in the Radio Interface page.
Can you please check?
73. Dan
4Z5SL
#4 Posted : Sunday, February 3, 2013 4:55:04 PM(UTC)
Ok, you can default it to 3 by going to log/setup and selecting rig, rotor, and terminal.
That said, there LOGic is supposed to just use the rig if there is only one. That code is apparently ignoring the DISABLED flag -- a new feature. I will check it.
