Can USERFIELDS be increased past 254
#1 Posted : Tuesday, December 4, 2012 1:08:35 AM(UTC)
My main activity is contesting. I run N1MM for the contest and then load the N1MM ADIF data into Logic for analysis. I usually configure a form for the contest in Logic, re-score the contest in Logic, and then print reports for analysis.
I batch update from the QRZ XML call book. and as I receive QSL cards, I update QSOs with the various fields for awards progress. I usually don't actually apply for the "wall paper" - I just do it for my own satisfaction.
In the past, I have had several problems with the data in USERFIELDS silently exceeding the maximum of 254 characters. I have removed a lot of the personal user fields to stay under the 254 limit. Not a great problem - mainly about what equipment I used for the QSO. It was a lot of work with little reward.
I now run a check to see if any records are approaching the 254 character limit. The largest is currently around 205. Like this for a JA call in BARTG RTTY ...
SRX:7| CQZ:25| STX:1| EX1:214| MISC:214| CONT:AS| RXI:1| ITUZ:45| CALL_AREA:JA4| CON_MULT1:JA| CON_MULTPTS1:1| CON_MULT2:JA4| CON_MULTPTS2:1| CON_MULT3:AS| CON_MULTPTS3:1| CON_QSOPTS:1| IOTA:AS-007| PFX:JO4|
Can anything be done about this character length limit on USERFIELDS?
My guess is, NO, not without a lot of re-programming on your part.
Clearly I can stop re-scoring the contest in Logic, and/or shorten the LAT and LONG data after the QRZ batch update for the contest.
I am grateful for any suggestions you may have?
#2 Posted : Tuesday, December 4, 2012 11:19:48 AM(UTC)
No, sorry, it is a limit of a character field in Visual Foxpro. I should put in some check that lets you know that the limit is being exceeded, however.
#3 Posted : Sunday, December 9, 2012 7:59:49 AM(UTC)
Oh, BTW, LOGic 8 would automatically import all ADIF fields fed to it, making storing values in USERFIELDS, UNLESS the field was predefined in Tools/Setup/Log Fields and ADIF fImport for that field was turned off.
Now it imports only fields that are in Log Fields and that are turned on of course.
