FISTS Award/Contest
wd9hbc
#1 Posted : Friday, November 2, 2012 9:27:13 PM(UTC)
When I try to run the FISTS Millionare award I'm getting a RunPRG error. It's in SCREEN.CONTEST.INI, error 13, Alias 'LOG' is not found......if you need the rest I can give it to you. This was working fine under LOGic 8, but does not work since I got LOGic 9. Any ideas?
Thanks!
Jim, WD9HBC
#2 Posted : Monday, November 12, 2012 11:09:11 AM(UTC)
Hi Jim:
Sorry for the problem.
I could not reproduce it here. Try the attached log form. Maybe yours is damaged or an old version or something.
(The only thing I changed was the URL of the rules).
Tnx &73,
FistsMillionaireAward.logform (10kb) downloaded 149 time(s).
wd9hbc
#3 Posted : Tuesday, November 13, 2012 8:34:24 AM(UTC)
I'm not using that logform at all. Is it a problem because I've customized the mainform? But it was working fine under v8. From my main page, all I'm doing is going to reports, contests, contest summary, Fists Millionaire, "get 3 or 4 errors", Rescore contest -- YES, "get 3 or 4 errors", report generated, view on screen, see report (but not updated with current entries).
Thanks!
Jim, WD9HBC
#4 Posted : Tuesday, November 13, 2012 11:59:14 AM(UTC)
Ok, not sure what is going on. The main log form isn't for contesting. You could turn contesting on I suppose, but I can't really say what is going on without seeing your main log form.
What happens if you try to score with the proper log form? I'm thinking your data will be OK -- you have FISTS logged after all. And we probably need to get you a good main.logform.
