LOGic Forum
LOGic Support
Logging
Using Logic with multiple Callsigns
Posts: 22 Location: El Salvador
Is there a easy way to set up Logic 9 when operating with with a different callsign from a different QTH? I want to be able to use the same laptop when operating in El Salvador as YS1GR and in the U.S. as W3MKT.
Tnxs & 73 Gary W3MKT (YS1GR)
We need to register you for both calls and send you another license file. Watch your email!
Ok, according to our records LOGic is licensed to both calls. So just go to tools/setup/station info and change your callsign. It will list the available callsigns.
LOGic Forum
LOGic Support
Logging
