Awards 1 information not correct
W7OO
#1 Posted : Friday, October 5, 2012 6:24:33 PM(UTC)
I was just checking in QSLs from LoTW.
I had worked JD1BHA and credited him to Minami Torishima. When I looked at what the ARRL in LoTW had credited they accepted it as Ogasawara so I edited the QSO in LOGic 9 to Ogasawara. I then ran Awards Update.
When I go to Awards 1 and enter in JD1-O it shows an "F" under the QSL band and mode just as it should. However, when I double click on the "F" to see the detail under QSL Received column for JD1BHA it does not show the QSL as received. It is blank.
Have you got any thoughts on what is going on here?
POOP
I see what is happening. There is a column for LOTW QSL received way over to the right (off my window). Now that I have drug it to where I want the column everything is good.
Sorry for the false alarm.
Bill
W7OO
#2 Posted : Sunday, October 7, 2012 3:09:37 PM(UTC)
Ok, no problem!
73
