New driver for rotor EZ
K3GC
#1 Posted : Friday, October 5, 2012 8:45:22 AM(UTC)
Subject to our conversation please write a new non-legacy driver for rotor EZ.
Gen K3GC
#2 Posted : Friday, October 12, 2012 9:33:39 AM(UTC)
Ok, here it is for you to test.
To install, we will copy some files into your LOGic install folder.
Exit LOGic.
Download the .zip file.
The DBF file goes in the LOGic install folder, overwriting the existing file.
The DLL goes in the ASSEMBLY folder inside the LOGic install folder, overwriting the existing file.
Then go to LOGic and change the driver for the rotor to the entry that DOES NOT say "(legacy)".
Let me know if it works!
RotorEZ.zip (6kb) downloaded 151 time(s).
K3GC
#3 Posted : Friday, October 12, 2012 10:42:36 AM(UTC)
So far it works perfectly with limited testing. I will continue to test and will let you know it there is a problem.
Gene K3GC
#4 Posted : Friday, October 12, 2012 3:33:49 PM(UTC)
Ok, FB. As long as it points the right direction and stops, it is OK. I will put it in the next update then.
