Callbook Interface does not automatically log info
#1 Posted : Monday, June 13, 2011 9:20:38 AM(UTC)
Click Log/Setup (look for the LOG menu at the top of the log data entry form), then click the CALLBOOK tab. Make sure auto logging from the callbook is turned on.
If you want to use a web callbook, make sure that No auto web lookup is not checked. Click the Setup button in the callbook form (Forms/Callbooks).
Also, make sure that you are using the correct procedure to add a new QSO.
  • Add a new QSO by clicking the + button or using a keyboard shortcut.
  • Type a call in the call field
  • Press {Tab} It is important that you press {Tab}.
Of course the callbook must be working in manual mode. To make sure it is working in manual mode, open the callbook form (click Forms/Callbooks). Enter a call and click the search button.
If you need help setting up Logic's callbook feature, see our VIDEOS page. There is a two-part series on callbooks here.
http://www.hosenose.com/videos/
