support of Ham Radio Delux
4x4pp
#1 Posted : Friday, September 21, 2012 11:46:45 PM(UTC)
Hi Everybody
I found just now that there is a Logic Forum.
Well it shows that sometimes you have to check in your area and
not going Far. (I am very glad to find the forum)
I would appreciate very much if somebody will give me the answer
whether the Logic 9 which I own and satisfied supports the
HAM RADIO DELUX SOFTWARE
If positive how can it be installed
If negative, whether there is a system to import the logbook
built in the HRD software to the Logic 9
Aric Native
4x4pp
#2 Posted : Saturday, September 22, 2012 8:11:17 AM(UTC)
Hi Aric,
you can export your logbook by HRD into the Logic9 program in a very simple way.
Choose logbook in HRD and select export.
You have to choose which fields to export because many fields supported by Ham Radio Deluxe are ignored by Logic9 why not ADIF fields. For this reason I would recommend you choose the export eqsl.cc only because are essential fields for the registration of a QSO. The other options will fill the records of the QSOs without logic will take account. Once the file is saved on your ADIF logbook must go to Tools \ Import Log Data \ ADIF and click on the file previously created by HRD. The game is done.
WN4AZY on 9/27/2012(UTC)
