Inaccuracies in the progress1 window
#1 Posted : Friday, August 17, 2012 8:02:07 AM(UTC)
I used for the first time the progress1 window inserting the value DXCC D6 to see how many connections I had made in various bands. I realized that I had 5 slots occupied in cw, but I knew it was true. So to make sure, in the logmain, I have filtered the DXCC D6 with "and" option for mode cw and are in fact three out QSOs. How come there this data discrepancy in two different masks? Where can I be wrong?
For completeness is attached a screenshot. Thanks
#2 Posted : Sunday, August 19, 2012 5:15:52 AM(UTC)
I may have figured out where the problem of QSOs that do not match. ( I think ;) )
Try to include a QSO with a call that you have already some QSOs but using a frequency and operating mode that you are missing. In the window Progress1 will be upgraded "worked". Considering that you can not finish it and delete it from the log you can see that the Progress1 is no longer updated and remains always "worked" enabled by creating this inconsistency in the data between the log and the Progress1. I think that needs a refresh on some index files, because even a reindex and pack puts in place the problem.
This occurred in O.P. XP SP3 but i tried also with W7 on laptop.
What do you think?
#3 Posted : Monday, August 20, 2012 9:43:55 AM(UTC)
Hi Mauro:
Thanks for your note.
Click Awards/Update Awards Progrss Info. See 7.3.4 of the manual.
If you enter someone in the log and don't work him, Undo (Esc key) will back him out if he has't been saved yet. If you enter a new QSO, navigate to another QSO, etc, then it does get tallied. So do Update Awards Progress Inof.
Tnx fur using LOGic.
IK0CHU on 8/20/2012(UTC)
#4 Posted : Monday, August 20, 2012 10:43:00 AM(UTC)
I thank you for the clarification and of course everything works perfectly with the procedure recommended by you.
Soon I will submit another question that will resume a request that I had made ​​about some unusual dates that were displayed in the fields qslsdate and qsrdate.
Thanks for your patience ;)
