Interfacing CSS ROCSoftware with Logic9
#1 Posted : Tuesday, August 7, 2012 10:55:20 AM(UTC)
Hello Dennis,
I have a multimode data controller AEA DSP 2232 in addition to a KAM by Kantronics and I'd use it with logic9. I set the mask of the terminal as PKTERM, PACTERM, MULTICOMM to interface Logic9 with the CSS software. The program says it can not find the file CSSTNC ******. EXE. I have a licensed program of the Radio Operations Center Software CSS, but looking into the installation directory \ Program Files \ pacterm98 (to KAM) or \ Program Files \ Pacterm99 (for AEA) I did not find the executable file that affects the logic9. I can use it in terminal mode but in this case I can not use the specific commands of the ROCS software. Can you help me on this? Thanks for your interest.
#2 Posted : Wednesday, August 8, 2012 5:35:13 PM(UTC)
I wonder of the current program from CSS is still compatible with the PKTerm intercface?
I'll look at the code and see, but as I recall, if it is already running, LOGic would detect that and not ry running it again. So start the other software first and see what happens. If you still get the error "Cannot find CSSTNC.EXE" then LOGic is not seeing the COM object or DDE that it is expecting.
