Awards Progress Update --- REJECTS
#1 Posted : Sunday, July 29, 2012 4:35:27 AM(UTC)
using the awards menu and the submenu to scan my archive I've received, as you can see in screeshots the errors specified (84).
Some mistakes I've adjusted because of a simple resolution. Now I have left only errors relating to American counties. How is this possible? Have I a wrong archive of U.S. counties? I have not changed anything from the original. Can you help me telling me how to solve the problem or should I download a new updated file?
Thanks for all
#2 Posted : Sunday, July 29, 2012 4:50:45 AM(UTC)
I'm sorry .... I forgot:
because they are often errors that refer to some callnames that are repeated on different dates, to understand at first how many calls are wrong is also possible to make a call to sort, as well as by date?
Thanks agn
Mauro
#3 Posted : Monday, July 30, 2012 1:00:02 PM(UTC)
Hi Mauro:
LOGic logs counties from a United States Post Office list using ZIP code. It is close to an actual county list, but not exact. For instance, LOGic has IL,DE KALB instead if IL,DEKALB. In this case I think LOGic is wrong. Just go to tools/setup/list of valid values and fix IL,DE KALB.
But most, like VA,SUFFOLK CITY are indeed not counties.
If you track counties the only solution is to fix them manually. IF you don't track counties, then don't worry about it. Turn off callbook lookup of counties in Log/Setup.
