Hi Bob:
It does indeed look like there is a problem there. However, I am unable to reproduce it here, and have had no other complaints.
Try Awards/Update Awards Progress Info. You can test using the TEST SPOT feature of the spot log Options tab.
I would like to see the VALUE column of the spot log. Does it have 9A in it?
Also, what is SPOT LEVEL set to?
