Power in CW Keyer memory
W7OO
#1 Posted : Friday, July 20, 2012 10:25:13 PM(UTC)
I want to put the power from my Main Log form in the CW keyer so I can send it. I first tried putting it in a long string of other stuff and got an error when I tried to save it. Then I tried putting just PWR in a keyer field by itself. Logic gave me the same syntax error message and offered to bring up the expression builder (I'm not sure that is what it was called). I noted that when I selected power using the expression builder that it put LOG.pwr in the field but I still got the same error when I tried to save it. What is the proper syntax to get power from the main log form and put it in a CW keyer field by itself.
I might add that I have many other iif statements etc running in other CW keyer fields. They are all working just fine. It is only power that I am having trouble with.
Bill
W7OO
#2 Posted : Sunday, July 22, 2012 8:45:26 PM(UTC)
Hi Bill:
You need to do something like this:
TRANS(PWR)
or more realistically,
"MY TX PWR IS " + TRANS(PWR)
PWR is numeric, that's why it requires special treatment. TRANS() converts any data type to string.
You can get fancy:
IIF(PWR>0, "MY TX PWR IS " + TRANS(PWR), "")
This way the macro will send nothing if your power field is not filled in. Otherwise it would say
MY TX PWR IS 0
which is really really QRP hihi.
W7OO
#3 Posted : Monday, July 23, 2012 12:59:53 PM(UTC)
Thanks for the fast reply.
I still can't make it work!
When I enter "My pwr out is " +trans(pwr) the keyer sends [my pwr out is *.**]. If I put just trans(pwr) in a memory it sends *.** so it is consistent!
Thanks for any help you can give me,
Bill
W7OO
#4 Posted : Monday, July 23, 2012 2:00:16 PM(UTC)
Ok, sorry. You need
TRANS(PWR, "####")
