network connection for K4
N7IP
#1 Posted : Thursday, March 12, 2026 5:32:56 PM(UTC)
Dennis, I need access to my K4 using the network. I'm no longer using a local PC. Do you plan to add network access?
Bob, N7IP
#2 Posted : Tuesday, March 17, 2026 8:40:49 PM(UTC)
Hi Bob:
Is this an Elecraft?
Can you send me documentation on doing this? Pse post it here.
N7IP
#3 Posted : Tuesday, March 17, 2026 10:21:13 PM(UTC)
Yes, Elecraft K4. The change in Logic would be to add a network address as an option in the dialog where we input radio interface info. Now, the only option for "port" is a com port.
Bob
#4 Posted : Saturday, May 16, 2026 5:18:28 PM(UTC)
Bob
Dennis, any movement on this one?
#5 Posted : Friday, June 5, 2026 9:19:34 AM(UTC)
Bob
No, sorry. I am trying to get an update out to fix the webdriver errors. I did get that fixed last night.
Unfortunately this change is a lot more than accepting an IP address in addition to a COM port. Every call to communicate with the rig will be different.
Not saying it won't ever get done tho. I will look at the Elecraft site and see if there is documentation or better yet sample code.
#6 Posted : Monday, June 8, 2026 7:10:34 PM(UTC)
I got using Google AI:
I don't have a K4 but it might be possible using VSPE - Virtual Serial Port
* Add a comport
* Configure it to the K4's IP address and TCP port using TCPClient
* Set LOGic10 to use that virtual port
Guest (6)
