How Logic uploads
#1 Posted : Sunday, February 22, 2026 9:04:06 AM(UTC)
I realized this some time ago, but it finally got to the point it really annoys me. scenario - you start to upload to LoTW, but for what ever reason have second thoughts. If you get to the point that you have the notepad screen showing what logic in going to upload, and at that point say NO, I DON'T WANT TO DO THAT, it doesn't at that point matter what you do.....it doesn't matter how you try to stop the upload....you're screwed. It WILL complete the upload. The only way I have found to make it quit is to kill the Logic process in the task manager, when it really should stop if you close most anything else. Is there anything that can be fixed in this?
WN4AZY on 2/23/2026(UTC)
#2 Posted : Monday, February 23, 2026 11:36:34 AM(UTC)
Hi Doug, hope you are well !!
So, if you upload to LoTW and you get the notepad screen, then you have LOGic set to review the QSO's to be uploaded before it actually does. That "review" screen only serves to allow you to review the upload and edit it if needed before it actually uploads. If you close that screen or x-out of it the upload process continues, it doesnt stop it. The next screen that should pop-up is I believe a TQSL related window, its looking for a date range for the upload should you need to specify one, but it has a radio button "cancel", maybe try clicking on the "cancel" button and see if that stops the upload. If I remember correctly (hihi) I think it exits the upload process, not 100% sure but try that next time and see.
#3 Posted : Monday, February 23, 2026 3:35:44 PM(UTC)
Hi Brad, how's things?
When I upload, I don't ever see a TQSL box, everything going on there is done in the background. Thanks though!
#4 Posted : Monday, February 23, 2026 10:10:05 PM(UTC)
I will put a CANCEL button on the ADIF EXPORT OPTIONS window. I hope it is just an oversight and there is no reason that I didn't put one there already....
You can cancel from TQSL. If TQSL is not coming up when you close the preview window, you have bigger problems. How do you upload to LoTW?
#5 Posted : Monday, February 23, 2026 11:22:42 PM(UTC)
Dennis, I don't remember ever seeing a TQSL popup to upload. Just to check, I tried to reupload some data and a TQSL warning window popped up. I have never had a problem uploading.
#6 Posted : Monday, March 2, 2026 4:10:06 PM(UTC)
Attached is a screenshot of the TQSL screen. You may have not realized that this is actually TQSL and not actually a part of LOGic.
DH WN4AZY
#7 Posted : Monday, March 2, 2026 4:35:50 PM(UTC)
Yeah, I see that if I open TQSL directly. It never shows up when I upload to LoTW. The only other time I see anything TQSL related is if I have dupes in the upload, I get a TQSL warning in that case.
