NOTE! LOGic must be run with Admin privileges!
#1 Posted : Monday, January 19, 2026 7:41:33 AM(UTC)
NOTE that LOGic must be run with Admin privileges! (Not as Administrator necessarily).
If this is not done, the ERRORLOG file will not be created, and you will have error messages to the effect that errorlog.dbf cannot be found. And who knows what else you may run into.
Most users have admin privileges. If your login user does not, an alternative is to run LOGic AS ADMINISTRATOR. Right-click your shortcut icon, Properties, Compatibility. Under Settings, checkmark RUN THIS PROGRAM AS ADMINISTRATOR.
I will try to make the installer set this for any shortcuts it creates.
#2 Posted : Monday, January 19, 2026 7:45:43 AM(UTC)
Hmmm.... I'm already doing that. The call I got yesterday might have been an anomaly. It hasn't been a big problem.
#3 Posted : Monday, January 19, 2026 11:47:20 AM(UTC)
I checked "Right-click your shortcut icon, Properties, Compatibility. Under Settings, checkmark RUN THIS PROGRAM AS ADMINISTRATOR" and the checkbox was not selected.
I'm running the latest update, 10.0.31 in Windows 10 Pro.
I'm not having any issues with LOGic currently but wanted to share with you the latest update did not automatically select Run This Program as Administrator on my pc.
#4 Posted : Saturday, January 24, 2026 6:40:18 PM(UTC)
Same here, run as administrator not checked. No issues.
WN4AZY on 1/27/2026(UTC)
