Too many random error messages and program crashes
#1 Posted : Sunday, November 2, 2025 12:00:23 PM(UTC)
Just curious, how many out there get just too many random error messages (including out of memory errors) and program crashes/terminations??? Sometimes it will terminate with no error message at all... if I don't have it on one of my screens and am using WSJT-X on another screen, I make QSOs without logging them at all.. No telling how many QSOs I've made which didn't go into my log.
I've had this issue using the last few computers and it seems not to be getting any better.
BTW, I'm using an HP Elitedesk computer with Win 11 Intel(R) Core(TM) i7-8700T CPU @ 2.40GHz (2.40 GHz) 32.0 GB (31.8 GB usable). 1TB SSD.
But as I said, the problem didn't start with this computer, I've had it with the last few computers... just seems to me this program is not stable any more...and I've been using logic since LOGic 6 (I think) or before.
What's going on??? I do have almost 300K QSOs in my log... is that part of the problem??
#2 Posted : Sunday, November 2, 2025 1:22:22 PM(UTC)
Hi Allen,
Sorry to hear of the issues. I would check Windows Task Manager and see what your RAM utilization is. Mine is around 17%. With all apps running (LOGic, GridTracker2, (2) Instances of WSJT-X-improved, and (3) instances of Win4Icom) my CPU is averaging about 8%-10% (peaks run 15-18%). This might be something to watch to see if any process is affecting your PC utilization. Also check Windows Event Log and see if any errors are occuring. Sometimes running Disk Cleanup helps to get rid of any straggling temp files.
Its hard to say what could be causing random program crashes but when I replaced my old Win10 PC just a couple weeks ago I chose to do a totally clean install of LOGic and not just copy the old LOGic folder over and re-install on top. I found that several "issues" (none were program crashes) I was having with LOGic over the last couple years have disappeared. I think copying over "old" folders brings baggage. It takes a couple hours to bring the old logfiles, logforms, etc back over but well worth the effort.
I run in all the major contests including CQWW a week ago and LOGic performed flawlessly (as usual), I used it for logging the entire contest and so was up the entire weekend. All the other apps above were running concurently as well.
You have ten times the QSO's I have so can't speak to a high QSO count. Does LOGic crash when doing an Awards Update ??
WN4AZY on 11/5/2025(UTC)
#3 Posted : Sunday, November 2, 2025 3:27:24 PM(UTC)
Hi Allen,
No, not when I do that function.
#4 Posted : Wednesday, November 5, 2025 2:45:03 PM(UTC)
You cover a lot in that post. No, I wouldn't say that LOGic is particularly problematic.
A couple of things to start troubleshooting:
For WSJT-X not logging to LOGic, first check that the QSOs are in the intermediate ADIF file. If they are there, then there is indeed a problem with LOGic not picking them up. If they are not there, then we need to look at WSJT-X.
These crashes without errors: Look in the Windows event viewer after that happens. Just type EVENT VIEWER in the Windows search bar. Look under Windows Logs, then Application.
#6 Posted : Friday, November 7, 2025 7:44:55 AM(UTC)
I think I'd start with a new computer power supply. I've seen them do all sorts of flakey things when the PSU gets unstable. And I've seen it happen with brand new supplies, too. Replacing the supply with a new, good supply fixed it.
#5 Posted : Friday, November 7, 2025 3:18:14 PM(UTC)
Dennis: What I said is that LOGic crashed without any indication or error message because another window was open over it. WSJT didn't log QSOs because LOGic had crashed and terminated without my knowledge.
I will look at Windows event view and report back.
Also, I've noticed issues when trying to download or upload to eQSL. I'll advise the error messages next time it happens, but it does happen often. I don't have any issues with any other programs, including WSJT, N1MM, Microsoft programs, etc., only LOGic. After my last computer crapped out, I thought all issues might go away with a new one, but that was not the case. I have a lot of LOGic windows open, maybe it's too much for the program.
WN4AZY on 11/10/2025(UTC)
#7 Posted : Sunday, November 9, 2025 10:54:35 PM(UTC)
OK, tonight I tried to import eQsl records, after importing LotW records. I got the attached error message, afterwhich LOGic terminated without additional input. After reloading LOGic, everything worked just fine.
Screenshot 2025-11-09 215125.png (16kb) downloaded 72 time(s).
#8 Posted : Monday, November 10, 2025 9:25:38 PM(UTC)
FB on your explanation of the WSJT-X problem.
Thanks for the error message.
Is the error reproducable?
Another thought. We used to have a lot of problems with non-FTDI RS232=>USB drivers. Also, the USB=>RS232 drivers that come with rigs did not seem to be a problem. Anything else could cause instability. And, hardware can go bad and cause wierdness. My USB web cam caused crashes, though with Windows, and not LOGic particularly.
Please try temporarily disabling any radio or rotor interfaces in LOGic, and see if stability returns.
#9 Posted : Friday, November 14, 2025 4:21:23 PM(UTC)
Here are today's error messages. All happened while running WSJT-X. Clicking IGNORE allowed software to continue. No LOGic crashes or terminations today.
Last email you mentioned non-FTDI RS232=>USB drivers. I have confirmed that I am running the correct drivers and there is no external RS232=>USB cable (built into K4D radio). These are the exact same error messages I got when using a K3 and a different computer. Seems like that might rule out the radio and computer so some extent. Are there any old files that I should delete that could cause this issue?
Screenshot 2025-11-13 222715.png (44kb) downloaded 67 time(s).
Screenshot 2025-11-14 133745.png (16kb) downloaded 59 time(s).
#10 Posted : Thursday, November 20, 2025 10:14:00 PM(UTC)
Ok, the Webdriver error to a localhost address means that LOGic is trying to display a web page that was created locally.
(Agree it is not an RS-232 COM port error.)
What options that use a web browser are you using in LOGic?
#11 Posted : Friday, November 21, 2025 7:23:47 PM(UTC)
I use Chrome, and always keep it updated.
#12 Posted : Friday, December 5, 2025 4:03:44 PM(UTC)
Sorry slow in geting back to you.
What FEATURE in LOGic do you use that uses your Chrome browser?
This page was generated in 0.088 seconds.
