Are you running a Flex Radio remotley with Logic? I need help
KV3R
#1 Posted : Thursday, October 16, 2025 3:56:33 PM(UTC)
Was thanked: 2 time(s) in 1 post(s)
I am running a Flex 6600 radio remotely. If I am running FT8 remotely all of software is on the computer at the station. I am able to have
Logic log my contacts and read the frequency from the radio. I can switch antennas and turn the rotor.
If I switch to SSB I need to close the Smart SDR program that controls the radio at the radio location. I then open the same SDR program on
the computer that is not at the radio location. Logic then will not read the frequency or log a contact. If I change bands on the radio the antenna switch box will change to the correct antenna. If I need to turn the rotor I have to make the computer screen at the radio location
the active screen. Maybe I need to have 2 monitors at the location I operate from. One to control the radio and one that is at the station to control everything else. But that doesn't solve the issue of logic not reading the frequency or logging the contact.
Anybody have an idea?
73, and Thank you
Bill KV3R
#2 Posted : Tuesday, October 21, 2025 11:23:59 AM(UTC)
Was hoping someone else will jump in here. I will try.
So LOGic is running on the remote computer as well, right? Everything is running locally as far as the rig, LOGic, FT8 are concerned. Everything works as if you were sitting at the remote computer. Except you are not actually there. You are logging into that computer remotely, right?
In this scenario, is LOGic getting the mode and freq from the FT8 program or from the radio?
Answer this, then we will continue.
