Server Down ??
#1 Posted : Monday, July 7, 2025 1:33:34 PM(UTC)
Was thanked: 203 time(s) in 180 post(s)
LOGic's updater doesn't seem to be finding the server. Same yesterday.
#2 Posted : Monday, July 7, 2025 4:26:36 PM(UTC)
Was thanked: 513 time(s) in 427 post(s)
Sorry, not seeing a problem at the moment.
#3 Posted : Monday, July 7, 2025 4:48:19 PM(UTC)
Must be something else, here's what LOGics Updater is returning...
PS: Also did the update to the updater client and get the same error.
From LOGic Updater.png (93kb) downloaded 10 time(s).
#4 Posted : Thursday, July 10, 2025 6:33:20 PM(UTC)
3 days in, is anyone else seeing the same error as above ??
#5 Posted : Saturday, July 12, 2025 7:17:54 AM(UTC)
Was thanked: 89 time(s) in 82 post(s)
Hi Brad,
for Your information, here it's no problem. All fine.
K8ZM on 7/12/2025(UTC)
#6 Posted : Saturday, July 12, 2025 11:39:03 AM(UTC)
Hi Mauro,
Thanks for the reply !! Hope all is well !!
Don't know what's going on but all was good until a few days ago and now the updater keeps throwing the error. I guess I have to go back and see if any Windows updates were the cause. Nothing else here has changed and there have been no changes to the Firewall. I also checked to see if the Firewall was blocking anything but can't find anything wrong.
Its always something !!!
PS: Just Reinstalled LOGic just to be sure, same error. If running an update from within LOGic I get "OLE!Dispatch exception code 0 from mscorlib: Could not establish secure channel for SSL/TLS with authority 'updatedistributionservice.hosenose.com'..." (attached) along with the previous error.
#7 Posted : Sunday, July 13, 2025 5:20:32 PM(UTC)
Hi Brad,
Yes, thank you. My heart seems to have stabilized, even if things aren't the same as before. There's still a constant sense of anxiety due to the knowledge of what happened.
Regarding the update error, if you've already verified that it's not due to the firewall or proxy server, try checking if your browser's security settings are updated and allow the use of recent TLS protocols. You could also check that access is exclusively HTTPS. The client and server are having communication problems, and that's where the handshake error occurs. I'm just guessing, but Dennis can certainly give you the right advice. Also consider the possibility of an expired SSL/TLS certificate. I hope he fixes the problem soon. I seem to recall, however, that version .30 was updated twice. Following Dennis's advice in a forum post, I also redownloaded it, but I don't remember the real reason.
I'm working on Multi/Multi, but the main problems are managing digital QSO archives by HF and V-U-SHF categories in unique and shared archives. I can't seem to find a solution, especially because the various software doesn't seem to have the ability to customizable addresses that can point to a single database per category to avoid duplicate connections.
What's my fault if I'm a crazy old man? Hahahaha. I have to do something to kill time.
Kind regards.
#8 Posted : Tuesday, July 15, 2025 11:02:00 AM(UTC)
Thanks Mauro,
I'm sure that experience will not easily be forgotten !! But, your doing the right thing !! Being "crazy" is the perfect solution and channels your anxiety to your Multi/Multi dilemna !! BigGrin
So, I think i have exhausted what I can do. I have turned off the Firewall and Virus Protection, checked browser settings (Microsoft Edge) and insured its the latest version, checked TSL/SSL settings, performed Microsoft SFC /scannow with no errors, as well as other stuff like re-install LOGic, perform Clean, clear temp files, perform Microsoft Disk clean-up including system files and reboot of the PC, most of this is un-related but I am a loss so I tried everything but the kitchen sink. The error is the same and seems to indicate the update server site is being blocked.
I'm out of ideas...
#9 Posted : Wednesday, July 16, 2025 9:57:43 PM(UTC)
Never seen that error.
Here is a direct link. Paste this in your browser:
http://distribution.hose...LOGicUpdate_10.0.30.exe
Run the file after it downloads.
That will reinstall the updater, and might fix it.
#10 Posted : Wednesday, July 16, 2025 10:39:52 PM(UTC)
Sorry but I get the same error.
PS: Running the latest Edge browser v138.0.3351.95 (in fact just updated today). Also went to SSL Labs and ran a test for SSL/TLS Browser Capabilities, Protocols reported as follows:
TLS 1.3 YES
TLS 1.2 YES
TLS 1.1 NO
TLS 1.0 NO
SSL 3 NO
SSL 2 NO
The attached pic "ProgramError" is what I get when trying to check for updates from within LOGic (Help/Check for updates) followed by the pic "LOGic Updater-UnhandledException". The Program Error says it could not establish a secure channel for SSL/TSL, the UnHandled Exception says site blocked because it may contain unsafe content. I posted these pics before but again here. If I run the updater from LOGics program folder I dont get the "ProgramError" but it does throw the "UnhandledException".
LOGic Updater-UnhandledException.png (93kb) downloaded 3 time(s).
#11 Posted : Friday, July 18, 2025 8:12:29 PM(UTC)
OK, try this:
https://distribution.hos...LOGicUpdate_10.0.30.exe
I changed the link that the server uses to https. Try the updater again.
Other things to try -- use a different browser. I would try firefox -- Edge and Chrome are based on the same code.
#12 Posted : Friday, July 18, 2025 11:54:11 PM(UTC)
Thanks but exact same error.
Trying another browser just not in the cards.
Thanks for trying !
#13 Posted : Sunday, July 20, 2025 6:58:51 AM(UTC)
The above https: direct link doesn't work??? Can you get to our web site hosenose.com? Is this the same computer you are using to post here? Maybe use your phone to download it.
I could log in and take a look. I might see something....
#14 Posted : Sunday, July 20, 2025 10:08:41 AM(UTC)
The linked worked fine but installing it resulted in the same error as before. I dont see another browser as a solution for me so not sure where i'm going with this at the moment.
I have no problem with you logging in and you've done it before, I would just say I had three 4kUltra HD monitors and all running at 3840 x 2160 resolution and still do, I seem to remember you had some issues with how the screens displayed on your end....but I'm game. Maybe sometime this week if your available.
#15 Posted : Monday, July 21, 2025 10:48:07 PM(UTC)
While most of this is over my head, I'm trying to figure out whats going on. After sending the first paragraph of the unhandled exception error text to an AI bot for help, here's what it replied with;
Hope this can help get to the source of the problem.
LOGic Updater-UnhandledException.png (93kb) downloaded 1 time(s).
TF5B, Guest (3)
This page was generated in 0.100 seconds.
