K4 Driver may need update
#1 Posted : Thursday, March 13, 2025 5:20:36 PM(UTC)
I've noticed on my new K4D that when I click on SET RIG, VFO B does not always get updated (frequency and/or mode). It's possible that there may be some different driver requirement than what the K3 needed. Do you mind looking into this? I will act as your beta tester if needed.
#2 Posted : Sunday, March 16, 2025 8:01:05 PM(UTC)
I would be happy to help with this. However, I have had no other reports of this, and the intermittency does not point to LOGic sending the wrong commands for the K4.
When it fails, does immediately retrying usually or sometimes work, or does it work for a while then not work for a while?
I would start by unplugging are replugging all cables. But you'd think if it were a hardware issue, it would fail on other actions as well. Don't know.
Let me know. Meanwhile I will look at the code and see what is different if anything about dealing with VFO B.
#3 Posted : Sunday, March 16, 2025 9:25:25 PM(UTC)
The problem with VFO B is consistent, not intermittent. Clicking on "Set rig" rarely fixes the issue...VFO B is not affected (frequency, mode or split).
Wonder how many others here have K4's?
On a separate note, I noticed today that 'Set Rig' and the 'Log' buttons on the LOGic Band Map do not work at all.
