info form size
#1 Posted : Saturday, February 22, 2025 9:20:21 PM(UTC)
Was thanked: 160 time(s) in 142 post(s)
Dennis, is there a way to make the info form sizeable like all the other forms are?
#2 Posted : Tuesday, February 25, 2025 6:43:20 AM(UTC)
Sure. The exact same way. Right-click in the background area of the form, then select a larger or smaller font.
DH WN4AZY
#3 Posted : Tuesday, February 25, 2025 7:10:26 AM(UTC)
That wasn't what I was talking about. All the other forms you can grab the lower right corner of the former by left click/hold and drag that corner/left side make the form whatever size you like.
Doug W5GA
#4 Posted : Sunday, March 2, 2025 8:19:22 AM(UTC)
You can do what you describe with forms containing primarily grids, like the log form browse window or spot log. You cannot do that with the log data form. You can only select a font size. The log form is special in that you can customize the field layout. The other forms -- lists of valid values, etc. you can only select a font size.
What are you trying to achieve? Do you want to totally change the layout of the info form, or is font size selection too coarse?
W5GA on 3/2/2025(UTC)
#5 Posted : Sunday, March 2, 2025 8:35:37 AM(UTC)
OK, that's what I was looking for. I'm trying to maximize the use of screen real estate, and being able to adjust the info form would have helped that, but if I can't, I can't. I've played with fonts, and it does help some but it also makes my ageing eyes hurt when I do too much.
WN4AZY on 3/3/2025(UTC)
