Radio goes into xmit when starting LOGic
WB2WJF
#1 Posted : Thursday, January 9, 2025 10:58:01 AM(UTC)
Using K4D, windows 10 , Logic v10 has worked in past. I must have messed up some settings and now when I open Locig the radio locks into transmit and nothing works to correct it other than turning radio off and then back on. Where do I find the settings that need to be corrected?
ross
#2 Posted : Thursday, January 9, 2025 12:21:11 PM(UTC)
Has this worked before??
If so, you can click on:
Tools>Setup>Misc ham setup,rig,TNC>Radio Ifc
to check your setup.
If this hasn't worked before go the comport in the Device Manager and check the Advanced Settings and make sure, "Disable Modem Ctrl At Startup" is checked and "Serial Enumerator" is unchecked.
73 Kyle, WA4PGM
WN4AZY on 1/20/2025(UTC)
WB2WJF
#3 Posted : Friday, January 10, 2025 6:58:53 AM(UTC)
Hi Kyle,
Thanks for the quuick response. Devicce manager was set properly and I have been using L10 for a long time. I went back to setup and deleted my TS-200 and
IC-7300 and basically startedd over. Now things seem to be OK. I wish I knew what really correccted the problem. I have been using Logic since the beginning .
Dennis wrote a great program.
1 user thanked WB2WJF for this useful post.
wa4pgm on 1/10/2025(UTC)
#4 Posted : Friday, January 10, 2025 9:29:27 AM(UTC)
Great! Good to see everything working again. Happy New Year!!
#5 Posted : Monday, January 20, 2025 11:07:39 AM(UTC)
Probably something to do with the DTR or RTS settings for the radio port.
WB2WJF
#6 Posted : Monday, January 20, 2025 12:15:15 PM(UTC)
Great to hear from you. I am using a new K4D and it has 2 comm ports. I had a setting wrong and it keyed the radio every time I started LoGic. Have it fixed now. By the way, how do I set up a cluster different than DxSummit for spotting.
Thanks,ross
