FoxyPreviewer latest versions issue
#1 Posted : Friday, August 23, 2024 10:03:02 PM(UTC)
I have been updating FoxyPreviewer for quite some time without issue and was using v3.00.307b-2024-08-07 successfully. I tried to update to v3.00.311-2024-08-17 and after hitting print-to-screen from LOGics dialog box FoxyPreviewer opens for a split second then closes. You can just barely see it open then abruptly close. LOGic's print dialog box remains open and no errors are thrown nor does anything lock-up. Same issue with subsequent versions 3.00.312-2024-08-12 and 3.00.313-2024-08-22. I attached the update history from v3.00.307b which was working fine.
Just an FYI FoxyPreviewer version v3.00.307b-2024-08-07 works, v3.00.311, v3.00.312 and v3.00.313 don't work.
73 de Brad, K8ZM
#2 Posted : Monday, August 26, 2024 4:13:06 AM(UTC)
Thanks--I'll read the docs and see if I need to call it differently.
K8ZM on 8/26/2024(UTC)
