Posts: 5 Location: Helena, AR
Hey Dennis, My issue is with exporting eQSL only. import is working just fine. the program will make the adif file however when it goes to connect with eQSL i get a screen that has ???? in the date. I am using windows 10 and Logic 10.0.28 . See attachment Joe N5MIG
Hi-- Sorry for the problem. The key is where it says MULTIPLE ACCOUNTS MATCH ... Can you widen the column to get the whole message? I do not know the solution offhand. I recall that there was previous discussion about that here on the forum. https://hosenose.com/For...le-location-logins.aspx
https://hosenose.com/For...s-uploads-download.aspx https://hosenose.com/For...-eQSL-import-error.aspx Hopefully someone will read this and have the answer. If not I will study the above posts. Tnx & 73, Dennis WN4AZY
Hey Dennis, thanks for the response. As you requested I expanded the field you requested. Please see the attached. Joe N5MIG
