eQSL -Export issue
N5MIG
#1 Posted : Tuesday, June 11, 2024 8:51:39 PM(UTC)
Hey Dennis,
My issue is with exporting eQSL only. import is working just fine. the program will make the adif file however when it goes to connect with eQSL i get a screen that has ???? in the date. I am using windows 10 and Logic 10.0.28 . See attachment
Joe
N5MIG
N5MIG_EQSL_LoGIC_ UPLOAD_BOX.JPG (145kb) downloaded 103 time(s).
#2 Posted : Wednesday, June 12, 2024 10:41:57 AM(UTC)
Sorry for the problem.
The key is where it says MULTIPLE ACCOUNTS MATCH ... Can you widen the column to get the whole message?
I do not know the solution offhand. I recall that there was previous discussion about that here on the forum.
https://hosenose.com/For...le-location-logins.aspx
https://hosenose.com/For...s-uploads-download.aspx
https://hosenose.com/For...-eQSL-import-error.aspx
Hopefully someone will read this and have the answer. If not I will study the above posts.
N5MIG
#3 Posted : Wednesday, June 12, 2024 12:25:51 PM(UTC)
Hey Dennis,
thanks for the response. As you requested I expanded the field you requested. Please see the attached.
Joe
N5MIG
Guest (5)
