If you are a paid-up 1010 member, would you help me?
#1 Posted : Friday, February 2, 2024 10:02:01 AM(UTC)
I have had several requests to "fix" LOGic's 1010 membership import. The data disappeared from the old URL.
I found this:
https://ten-ten.org/data...4-member-lookup-utility
If you are a paid-up 1010 member, could you please send me the 1010.txt file referenced on that page? I will then fix the 1010 import.
#2 Posted : Friday, February 2, 2024 2:31:21 PM(UTC)
Was thanked: 231 time(s) in 208 post(s)
Sent the file just a few minutes ago....
#4 Posted : Friday, February 2, 2024 8:04:28 PM(UTC)
Was thanked: 80 time(s) in 75 post(s)
Hey Brad, where did you find that 1010.txt file?
Allen N5XZ #4530
#5 Posted : Friday, February 2, 2024 10:52:46 PM(UTC)
Hi Allen,
https://www.ten-ten.org, then MISC, ONLINE SOURCES>>, DATA SOURCES. File is 1010.zip. Don't think you need to be a paid member, just have an active (registered) login.
73, Brad K8ZM, #55448
N5XZ on 2/3/2024(UTC)
#3 Posted : Thursday, February 8, 2024 3:59:55 PM(UTC)
Sorry, I didn't get it. But someone sent me one he got from the lookup utility as per my first post. It looks like this:
K1RAW w4hwa w6meb w3pon wa9fsew3mce w3gk k4flc k6pjo w6pgm w6tch w6tvd K6OYX wa6qkcwb6ggtw6vad w7wlv WA6UUYw6jjy wa6vfqWA4DDGw7aev W6KIR k6vds W6ULX w9dla wb6bndWA6ESTW6RW kd6xt k6qlj wa6jafK7BBN W6VEE w4bur WA5BGHwa6uzkW6PLU WB6HDWn5cuq wb6imhw6css W0GEO wb6gglk6gwh W6SFC w6cyw w6itb w6vga k5dit w6vds k6gvp WB6RYPWA6EXYk6jwy WB6FNSWA6UGIwa6dftWA6RIKwa6nsdW6EED K6YUI w8akf k6rxj AK7D WA6VHYw6fav k6rj N6MJC w1eed wa6tqcve7dt wa6tfywa6lweK6BRC wa6qikWB6KOSn7eiq k0wzx w6syf WB6IVFWA6JQRK6UBY w6kkq WB6QWLw3qcp k8jzn w7vrb w6cks wa6arck6zpw w6rnx wa6bdlw6mlz w6ebk k6oqq k6pwo w6ffn K6AA wa6gzkW6YY WB6NUVwb6lwwKH6I W6TCH WA6PQIk6egd w6cho W6OI wa6cbjw4sgr wa0ghzw6dtx k6lha W6HIQ w6hur KH6FKRk6dzc w0fnv wb6bfkWA6JOCWB6TICVE3BPXWB6QWJW9RYM KT6M K4HWO WB4CNSOO5OO k8ejn VE7BTRw9cc wa6zzjW8PNT VE1AHWk6dcu W8WGR wb5fiiwa4warwa0iymW4LFA k6viz K4ZSR wa9fhlk6obv k4zss K0DZP K8IJD w6jx wa8cgqk0unr w9aky w6ehj K9PVE w9yve wb6gglW5NFG k6ahh k0sli wa8myfWA8SRVwb4cixk0rjr w1jnc WA6FJJwb6tvaWA4MCCW8JXU wb2uqdWB6FFYK6OVG n6ehr G3IUD k4gz wb8ebrw6hqq WB6ULJW6GLP WB6VZZYV4AR wb6yyiw6jjk w0acx w0qms K7OCO VE5UT k3tfv w0mel wa4zdiw4wim W0IKZ EA3GY
A big run-on text file, with blocks of 6 characters, one per call. K1RAW is 1010# 1, W4HWA is 2, etc. I assume the lower-case ones are silent keys. There aren't many later in the file.
Does the file you downloaded look like this?
Thanks & 73,
#6 Posted : Friday, February 9, 2024 6:11:54 AM(UTC)
Yup, looks like it. The last call in the list was N6ACA who is #78239, after his call looks to be a bank of unassigned 5-digit numbers up to 85000 each separated by a blank space.
1010.zip (290kb) downloaded 109 time(s).
WN4AZY on 2/11/2024(UTC)
