FixStuff prg
#1 Posted : Sunday, December 3, 2023 3:38:05 PM(UTC)
Is there a possibility to change the formatting of the processing start date in the fix stuff program which since version 0.23 has been reduced to 6 visible digits and with the sequence mm/dd/yyyy?
I have always entered the date as dd/mm/yyyy and only the first two digits of the year are visible in the yyyy field.
This evening I entered 01/12/2023 and to my surprise it processed the PFX for the entire year 2023 hihi.
Thank you.
WN4AZY on 12/4/2023(UTC)
#2 Posted : Tuesday, December 5, 2023 10:39:38 AM(UTC)
Thanks for the report. I fixed the code. The fix will be in the next update. Won't be long.
It uses whatever date format you have set in tools/Options/
IK0CHU on 12/6/2023(UTC)
#3 Posted : Tuesday, December 12, 2023 1:49:23 PM(UTC)
This has been fixed. Get the latest 10.0.25 update.
IK0CHU on 12/15/2023(UTC)
Guest (7)
This page was generated in 0.091 seconds.
