LOGic Forum
LOGic Support
Report Writer
DXCC Challenge/Top List progress report
Posts: 471 Location: Missouri
Thanks: 102 times Was thanked: 159 time(s) in 141 post(s)
This report is not picking up any RTTY/Digital confirmations, although it is supposed to. 73 Doug W5GA 73 Doug W5GA
Groups: Administrators, Beta Testers Posts: 3,259  Location: Auburn, GA Thanks: 1140 times Was thanked: 555 time(s) in 465 post(s)
I suspect it is something having to do with Modes setup.
Please go to tools/advanced/database commamnds. Type in these 4 commands:
? global.mode_arr[1] ? global.mode_arr[2] ? global.mode_arr[3] ? global.mode_arr[4]
(You can also copy and paste, probably will have to do them 1 at a time.)
The results should be:
CW DATA IMAGE PHONE
Hi Dennis, I did as you asked with the database commands, and the results were exactly as you said they should be. 73 Doug W5GA 73 Doug W5GA
Ok, don't know then. Best thing is to call me and I can log in & take a look. https://www.hosenose.com/remote_support.aspx
Tnx & 73, Dennis WN4AZY
Some updated info. If you look at the attached file: notice in the top right box it shows CW, DATA, IMG and PHO, and there is a total for each. Now, look on the lower left and you'll see Mixed, CW, Phone and RTTY. Data is not being translated to RTTY. 73 Doug W5GA
LOGic Forum
LOGic Support
Report Writer
