How do I clear the contest score window?
WB4HUC
#1 Posted : Thursday, October 26, 2023 3:12:07 PM(UTC)
I have created a new log form for the CWOPS Slow Speed Contest. I entered some QSOs for testing things like dupe checking and multipliers, and everything seems to work. My question is, since the contest score window now shows numbers for those contacts, along with numbers for the score, multipliers, dupes, and the like, how do I clear all that stuff out before I operate the next contest?
Mike - WB4HUC
#2 Posted : Thursday, October 26, 2023 4:05:59 PM(UTC)
Delete the contacts.
WN4AZY on 10/27/2023(UTC)
WB4HUC
#3 Posted : Thursday, October 26, 2023 4:56:48 PM(UTC)
I did delete the contacts from the log after I was finished testing, but the contest score window still shows the numbers from those test contacts.
WB4HUC
#4 Posted : Thursday, October 26, 2023 6:52:16 PM(UTC)
I think I figured it out. In the Contest Setup tab of the Log Settings window, I just changed the name of the contest and saved those settings.
I then close and reopend the Contest Score window and all fields were blank.
Hopefully that will do it.
This is the first time I've created and set up my own contest log form, so there has been a bit of a learning curve.
#5 Posted : Friday, October 27, 2023 9:33:11 AM(UTC)
After you delete the test QSOs, do Contest/Rescore contest.
WB4HUC
#6 Posted : Friday, November 3, 2023 10:56:32 AM(UTC)
Dennis, after my previous post from last week, it turns out the contest score windows wasn't really cleard. However, I followed your advice to do Contest/Rescore contest after deleting the test QSOs, and that did work. Thank you.
1 user thanked WB4HUC for this useful post.
WN4AZY on 11/6/2023(UTC)
Guest (12)
