DXCC reporting
#1 Posted : Thursday, October 19, 2023 8:06:27 AM(UTC)
Dennis, is there a way to see ONLY unworked entities? I know I can see them if I do full dxcc report, but I'd like to be able to do it without all that chaff, and get only what hasn't been worked. I don't need the 6 or 7 pages that a full report brings.
#2 Posted : Thursday, October 19, 2023 4:59:53 PM(UTC)
Go to (R)eports, (A)wards, select DXCC, Next, from the dropdown, Print Unworked Entities and check the box, Next, Next, Next, Finish, Ok.
Change the selection criteria from: QSL_RCVD $ "SFRWU" to QSL_RCVD $ "SFWU"
73s, Don
2 users thanked w2zi for this useful post.
WN4AZY on 10/19/2023(UTC), W5GA on 10/20/2023(UTC)
#3 Posted : Thursday, October 19, 2023 7:25:37 PM(UTC)
If you "really" want ONLY unworked entities, use select criteria QSL_RCVD $ "U"
Note the "Cards Needed for Award" report also works using the same criteria. If you dont need to print and just want a quick visual summary go to (A)wards, Progress (L)ist, select DXCC and just uncheck everything except for unworked.
#4 Posted : Thursday, October 19, 2023 9:56:04 PM(UTC)
I replied to the duplicate posting (now deleted) before I saw these fine replies. I moved my post here FWIW.
Yes.
You can use awards/Progress list. Checkmark only UNWORKED. You can right-click the grid to export the contents to a spreadsheet, and print this if you want.
To use the awards report, change the default select criteria from
QSL_RCVD $ "SFRWU"
to QSL_RCVD $ "U"
See the notes in the comment section.
Also check out the CARDS NEEDED FOR AWARD report.
#5 Posted : Friday, October 20, 2023 11:22:09 AM(UTC)
Many thanks everyone, exactly what I wanted!
This page was generated in 0.136 seconds.
