Spot Log Filter More Values
#1 Posted : Friday, September 22, 2023 9:12:53 PM(UTC)
Was thanked: 68 time(s) in 61 post(s)
Can I add more than 2 values to the Spot Log Filter? Lately, there have been a lot of good DX and I'd like to filter for more than 2 stations. The attached screenshot shows 2 calls that I'm filtering. Would it be possible to add additional values (Value 3, Value 4, etc.)?
If the option is already available in LOGic, I haven't found it using the FILTERING help file or I'm missing the section Confused
Vin,73
Spot Log Filter.JPG (41kb) downloaded 45 time(s).
#3 Posted : Sunday, September 24, 2023 12:00:06 PM(UTC)
Was thanked: 130 time(s) in 116 post(s)
Vin, if you go to spot log/alerts/setup, you can add as many as you want. Or is that not what you're needing?
WN4AZY on 9/26/2023(UTC)
#4 Posted : Sunday, September 24, 2023 6:09:06 PM(UTC)
Hi Doug,
I tried the alerts tab, went through the setup but I don't see the stations I placed in my alerts showing up in my spot filter.
The stations I placed in my alerts screen do show up in my log as worked but not in the spots.
I was chasing ZL7IO, T22T and VK9LAA all weekend either RTTY or FT8 so I setup my SPOT filters by call:ZL7IO and call:VK9LAA (screenshot attached) spot filters and wanted to add T22T but there are only 2 values one can enter in the SPOT filter setup.
I may be misunderstanding or missing something, but I only see 2 values that LOGic will currently accept.
I was wondering if Dennis might be able to increase the values columns 1 and 2 to whatever the user wants in order to have more stations show up in the spots window.
Spot Log Filter Step.JPG (42kb) downloaded 38 time(s).
#5 Posted : Monday, September 25, 2023 9:59:58 AM(UTC)
Hi, Vin
"I tried the alerts tab, went through the setup but I don't see the stations I placed in my alerts showing up in my spot filter. "
You won't, but you will get either Dennis or Fe telling you those stations have been spotted over your speakers, either by voice or by CW once it's set up.
#6 Posted : Monday, September 25, 2023 2:15:49 PM(UTC)
Thank you Doug Smile
#7 Posted : Tuesday, September 26, 2023 12:51:31 PM(UTC)
Just click the EDIT button on the filter form. The expression with the two calls is displayed:
(CALL='ZL7IO' OR CALL='T22T')
Change it to:
(CALL='ZL7IO' OR CALL='T22T' OR CALL='VK9AA')
But the Alerts tab should do what you want. It is a matter of switching to another tab as opposed to turning a filter on or off.
#8 Posted : Wednesday, September 27, 2023 7:48:18 PM(UTC)
Works like a charm Dennis...tried it out this evening and all 3 stations I was looking for all showed up in the spot log (CALL='ZL7IO' OR CALL='T22T' OR CALL='VK9LAA').
Thank you !
WN4AZY on 9/27/2023(UTC)
