CQ zone report
#1 Posted : Tuesday, September 26, 2023 9:36:10 AM(UTC)
I'm using the awards/CQ zone report. I have filters set to 30m and print unworked selected and prefer LOTW. I show 38 worked, 32 confirmed and 2 unworked. However, if you actually count by hand, there are 38 confirmed with either card or LOTW, and 2 unworked/unconfirmed. What I see on the printed report is that there are 6 entities showing a W for qsl received, and all 6 have LOTW confirmation. I have no idea how they got a w stuck in qsl received, as that isn't an option. Because it isn't an option, I don't know how to remove it. Any ideas, Dennis?
#2 Posted : Tuesday, September 26, 2023 12:43:14 PM(UTC)
Hi Doug:
Please try Awards/Update Awards Progress Info.
#3 Posted : Tuesday, September 26, 2023 9:08:15 PM(UTC)
Hi Doug:
OK, did update awards progress info. Nothing changed.
#4 Posted : Wednesday, September 27, 2023 8:53:32 AM(UTC)
Sorry, I rushed thru reading your question and did not understand it. I think I do now.
The statuses in QSL Rcvd do not correspond 1:1 with the options on the log form. You DID work these six zones, right? It is worked by virtue of merely being in the log. (Unless you enter Ignore for QSL RCVD and there is only one QSO for that zone in your log, in which case it will show as U for Unworked.)
In other words, the QSL Rcvd column will never be blank on the report. The W ties back into the select criteria. You could pull everything worked but no card for example. (However, the CARDS NEEDED FOR AWARD would be a better tool for this.)
I think all is normal.
Tnx for using LOGic.
#5 Posted : Wednesday, September 27, 2023 5:50:47 PM(UTC)
Dennis, please take a look this report. Notice at the bottom it says 9 confirmed. Notice how many check marks there are for LOTW confirmation. Do you get the disconnect now?
logic report.PNG (61kb) downloaded 130 time(s).
logic report.PNG (61kb) downloaded 126 time(s).
WN4AZY on 9/27/2023(UTC)
#6 Posted : Wednesday, September 27, 2023 8:36:32 PM(UTC)
Ok, thanks for the pictures.
I think I follow now. In other words, if you have LoTW, it should be Fulfilled, not Worked, right?
#7 Posted : Tuesday, October 10, 2023 6:35:41 PM(UTC)
Yes, and it should show up in the total, which it doesn't.
WN4AZY on 10/11/2023(UTC)
#8 Posted : Wednesday, October 11, 2023 12:21:56 AM(UTC)
I don't see that problem here, the CQZ reports (and others) tally correctly, i.e., Fulfilled is reported if confirmed either by Lotw or Paper regardless of whether the report is run "Has Lotw or Paper", likewise the totals are reflected correctly. I tried many other reports and have yet to find an instance yet of where its not. I'm curious to know what Dennis finds on this one. This isnt helping Doug but thought worth mentioning.
Hope Dennis finds the issue.
2023Oct11 - Yes, mine works as it should. I posted only to show it wasn't a widespread issue.
CQZ Rpt-Lotw ok here.png (69kb) downloaded 122 time(s).
CQZ Rpt-Paper ok here.png (70kb) downloaded 116 time(s).
#9 Posted : Wednesday, October 11, 2023 7:37:17 AM(UTC)
Brad, yours looks OK.
The key point of discrepancy here is that if HAS LOTW or HAS PAPER is checked, then QSL_RCVD should always be F. Yours is OK.
K8ZM has LOTW, but QSL RCVD is still W.
Note that the QSL RCVD column is not tied to paper or LOTW. It's just the overall status based on how you have QSLing set up.
Between relatives dying and getting married I haven't had a chance to look at this further. Thanks for bumping it.
#10 Posted : Wednesday, October 11, 2023 12:12:26 PM(UTC)
OK, I THINK I see what is going on.
I think LOTW is not turned on for CQZ. This gives the results that W5GA is seeing.
To fix, go to Tools/Setup/Log fields, spotting, & awards Tracking. Click on the binoculars and enter CQZ to pull up the CQZ field. Go to the Awards tracking... tab. Make sure that IS A QSL FROM LOTW OK? is checkmarked. If not, then do awards/update awards progress info.
The report IS working. It is not reporting LOTW as worked because LOTW is turned off for CQZ. Yet you DO have a LOTW confirmation. Confusing as hell to be sure. And don't know why anyone would want the results you are getting. I guess what should happen is that if LOTW is not enabled for the award in question, the report should not give you the option to PREFER LOTW. So my assertion in the second sentence of my above post is wrong.
Let me know what you find.
I'll go thru and set LoTW for all the ARRL awards. But that will only affect new installs.
W5GA on 4/2/2024(UTC)
