2 Pages<12
v10.0.9 screen pop-ups dont sync with multiple monitors
#21 Posted : Thursday, August 3, 2023 8:26:05 PM(UTC)
Thank you Dennis...I downloaded the latest version today...all the windows open in the main monitor or within LOGic with the exception of the "QSO Date Range" box which is one of the windows that opens during "Upload QSOs to LoTW" process.
I manually moved the QSO Date Range window to my main monitor made a QSO and tested the upload to LoTW and the QSO Date Range window opened in the second monitor.
No rush, I appreciate all the fixes with the latest version Smile
#22 Posted : Monday, August 7, 2023 4:56:36 PM(UTC)
Thanks as well Dennis !!!
I did run across a few that pop-up on monitor 2 after installing v10.00.18 [2023-08-02 22:20:18];
1) Tools/Export Log Data the "file to export" pop-up after you export and say "ok" is behind LOGics desktop (see pic). When it appears initially its centered and on-top until you export another file (in the same session).
2) Edit Adif Export, find and Replace window pop-up.
3) From Logform when you do a Get (click on the binoculars), also if you click on the waiterman (select user defined field).
4) In Misc Setup when you click on the 9-pin DIN connector icon (Com Port Usage).
I'll keep editing this post if anymore "pop-up"....hihi !!
Best 73,
WN4AZY on 8/8/2023(UTC)
#23 Posted : Tuesday, August 8, 2023 6:41:15 PM(UTC)
Thanks for letting me know!
#24 Posted : Tuesday, August 29, 2023 7:32:10 AM(UTC)
I had time this morning to chase a little DX and while setting up a Spot Log Filter, the Spot Log Filter window kept opening on my second monitor. I dragged it to my main LOGic monitor but it still opens in my second monitor.
WN4AZY on 8/29/2023(UTC)
#25 Posted : Wednesday, August 30, 2023 5:47:40 AM(UTC)
Thanks Vin. I fixed it here -- will be in the next update, whenever that is.
#26 Posted : Wednesday, August 30, 2023 10:23:53 AM(UTC)
Thank you Dennis...no rush Smile
#27 Posted : Wednesday, September 13, 2023 10:36:00 AM(UTC)
Playing around with 10.0.20, during the LoTW upload process, the "Date Range" window opens in another monitor.
No rush.
Thank you
WN4AZY on 9/13/2023(UTC)
#28 Posted : Wednesday, September 13, 2023 8:17:28 PM(UTC)
Fixed. Will be in the next update.
#29 Posted : Friday, September 15, 2023 9:35:40 AM(UTC)
PS. I actually fixed the ADIF Options dialog. Not sure what you mean by a date range. The update will be out later today. If it isn't fixed, please send me a screen shot.
#30 Posted : Saturday, September 16, 2023 9:10:53 PM(UTC)
Attached is a screenshot of the "QSO Date Range" window that opens up in my second monitor. This window is part of the "Export and Upload QSOs to LoTW" process.
Vin, 71
QSO Date Range.JPG (30kb) downloaded 153 time(s).
WN4AZY on 9/19/2023(UTC)
#31 Posted : Tuesday, September 19, 2023 11:41:05 PM(UTC)
I can't find that window in LOGic. It looks like it is from TQSL?
#32 Posted : Wednesday, September 20, 2023 2:29:01 PM(UTC)
Thank you Dennis....I didn't know that window was part of TQSL. Anyone else seeing the QSO date Range window or is it just me?
#33 Posted : Thursday, September 21, 2023 10:58:21 AM(UTC)
Yup, it's a part of TQSL, not Logic. It is a normal window, and you need to enter the requested data. If you are unsure of the start date, you can find it in the FCC ULS system under your FRN.
#34 Posted : Thursday, September 21, 2023 12:26:40 PM(UTC)
Thank you Doug. I learned something new ThumpUp
#35 Posted : Tuesday, February 25, 2025 2:18:25 PM(UTC)
Can you fix this pop-up issue ?? When doing Tools/Export Log Data, the export window 1st is on top of LOGics desktop until you actually do the export which then moves it behinbd LOGics desktop....see attached.
Not sure if this is the right place for this post but seems many window pop-up anomalies appeared here....
Thanks, Brad K8ZM
Guest (11)
2 Pages<12
This page was generated in 0.072 seconds.
