Report request
#1 Posted : Tuesday, September 6, 2011 4:15:20 PM(UTC)
Dennis, this isn't about the writer - this is one of my wish list items. Can you make reports so they respond to the up/down arrows and the page up/page down keys like other Windows apps do? For me, it's just a complete pain to have to use the sliders to move things around.
#2 Posted : Wednesday, September 7, 2011 9:30:07 PM(UTC)
Do you mean that you want to use the page-up & -down keys in the report preview?
The previewer is part of Visual Foxpro, so it probably can't be done.
VE2XK
#3 Posted : Saturday, June 16, 2012 7:55:51 AM(UTC)
There is a suggestion from me we talk about long time ago you don't have bring on Logic 9 or you probable forget it.
On the end of the report i mean were you are ask to print on screen or what ever you don't add
the button «PREVIOUS» for previous selection.
The big convenient to not have this buttons is to restart alway again and again a new report request and re-select etc from begin
were don't make the thing not easy to use.
See suggestion picture
Report end buton
Excuse my english
73's Michel VE2XK since Logic 5.
VE2XK
#4 Posted : Saturday, June 16, 2012 8:26:02 AM(UTC)
Hello,
Another suggestion i find would be great to add is to have another column on the report where is possible to see
also the qsl has LoTW confirmation acked or not in the same time way has the paper one.
This will show you clearly on the same report were from both confirmation are made without to re-ask
a new report for just LoTW confirmation for example.
I have over 640 grid's worked right now and without this column that make the thing not alway easy
to find which grid i have confirmed were not has paper was because on all side i have to search
which qsl card was not has paper acked but confirmed. I mean visualy
Report qsl paper & LoTW
Excuse my english
73's Michel VE2XK
#5 Posted : Sunday, June 17, 2012 9:05:36 PM(UTC)
On the PREVIOUS button. The report writer is supposed to default to the last report run when you click Reports. It is broken. I will look at the code.
On LoTW/Paper:
Do you know that if you select PREFER LoTW QSL IF AVAILABLE, then the column changes to LoTW? THen if LoTW shows up unchecked but QSL is Fulfilled, then you know it has to be paper.
