Error 1429 after upgrading
NS4X
#1 Posted : Thursday, August 31, 2023 9:47:29 PM(UTC)
Since upgrading to 10.0.19, I get the following error at every startup:
"Error 1429 OLE IDispatch exception code 0 from PDA.UtilFunctions: Method: set_DataSource Codebase: file:///C:/Program Files (x86)/LOGic/EntityFramework.DLL
Message: EntityFramework: An error occurred while executing the command definition. See the inner exception f has occurred in program PREFIXLOOKUPSETUP, line 50.
Attempt to continue?"
I click on "Yes" and the program finishes its startup and, as far as I can tell, continues to function normally. However, not knowing exactly why this error message is occurring has me concerned that there is a problem that may cause other issues.
I have reinstalled the upgrade and the problem is still there.
Bart, NS4X
LOGic error screen capture.JPG (28kb) downloaded 3 time(s).
#2 Posted : Monday, September 4, 2023 10:39:37 AM(UTC)
Sorry for the problem.
See if you can open tools/setup/bands without error. Look for the new POTA field. Try changing the value of one of the records and saving.
Try rolling back to a previous version and see if the error goes away.
