v10.00.17 LoTW Upload when done brings up adif export window
#1 Posted : Tuesday, July 18, 2023 8:58:38 PM(UTC)
Just did an upload to LoTW, it processed as normal except when it was done and you click on ok to mark the files as sent the export adif file window pops back up requiring you to close out of it. I'll try to capture it next time and attach a pic.
WN4AZY on 7/18/2023(UTC)
#2 Posted : Wednesday, July 19, 2023 12:22:19 PM(UTC)
Ok, so, what its doing is after you say yes to "Mark exported log records as sent to LoTW?", the next pop-up is "x Records marked as LoTW Sent", if you click on OK (the only choice) it pops-up the "ADIF Export Options" window, same as after you hit the "Export process and upload button in the "Upload QSO's to LoTW" window. Now, if you do nothing when the "x Records marked as LoTW Sent" window pos up (i.e. dont say Yes) but leave it sit there for a couple seconds, that window closes on its own. Dont remember it doing that before, but maybe I'm to quick on the trigger to have waited.
WN4AZY on 7/19/2023(UTC)
#3 Posted : Monday, July 31, 2023 9:42:41 AM(UTC)
The last several LoTW uploads after my prior post worked fine, no window pop-ups, no nothing Huh .
Not sure why, but all seems to be working fine !! Confused
You can take this off the fix-it list BigGrin
WN4AZY on 8/1/2023(UTC)
#4 Posted : Tuesday, August 1, 2023 7:01:00 AM(UTC)
I may have fixed something mid-stream. I am still working on all of the window placement and multiple monitors. Tnx for letting me know.
